Any tips on removing GTS aluminum gas cap?
jason427
Indialantic, FL
I just glanced at it, but it looks like after removing the bolts the filler neck might prevent it from just coming out?
Any tips???
Thanks,
Jason
Bonkers
DelaWhere? USA
There is a hard rubber seal around the inside of the cap that will flex through the hole. Its a REALLY tight water(gas)proof seal and will require fidgeting with it. You'll need a sturdy U-shapped hook to pull it back through when you put the cap back on.
