11k miles currently
I've had a small oil leak from the pan area since I purchased the car at 900 miles...not worried about it.
The window roll up hardware don't seem to be very robust. They rattle if you roll them up or down when driving. I don't open or close the doors while the windows are going up or down either.
Oil lines can start seeping or even dripping at compression fittings especially under hard use.
I've had to replace the clutch at 7k miles- clutch disk flew appart.
I had a new transmission warrantied at 5k miles - lost all the gears after a 2-3 shift.
ALSO...it's a DODGE what did you expect???
It's a flagship car but you can't expect the quality of part to be much better than the rest of the cars they produce.
I have a 2002 Jeep Grand Cherokee that in 60K miles has had; two rear diffs, one front diff., power sterring hoses, both power mirror motors, heater core and the dual zone climate control system replaced.
They build some nice cars....but they eventually fall appart sooner or later.
