ATTN: Multiple Wheel Set Owners! Solution to TPMS Sensor Woes!!!
Cape Coral, FL
Solution to TPMS Sensor Woes! Multiple Wheel Set Owners READ HERE!
I know many of you are sick of the constant nagging TPMS issues when owning multiple sets of wheels for street and track applications. Well, we finally have a solution coming soon that will make all your wheels work on your car, with the TPMS system functioning, AND without programming headaches!
We will be acquiring a special TPMS programmer and sensor system. Basically, you will take your primary sensor codes read at your local dealer with a DRB-III, E-Mail us a copy of the codes and the tire location, and we will program and send you a set of tire pressure sensors coded to mimic your other wheel set right out of the box, no programming needed!
Just install the sensors in your extra wheels, and swap them at will!
The car will not know the difference between the wheel sets, and will require no programming or learn time inbetween.
What does this mean to you?
1. SAFER track days
2. LESS Down Time
3. NO annoying Ding
4. PRE-PROGRAMMED replacements available to replace "dead" sensors
5. NO LIMIT to the number of wheel sets you can utilize!
6. NO COMPROMISE!
Best of all, it wont be expensive- in fact, downright cheap. The cost of the new sensors, PROGRAMMED, will be the same or less as what you would pay for a factory Dodge sensor, without the hassle of having to program your car to work with them as you would when changing OEM sensors out.
I would like to get a group buy or an introduction offer going on this- please add your name to this post if interested!
Cape Coral, FL
Pricing will be about 199.00 for all 4 sensors, programmed and ready to rock.
Any interest here? Lots of people have been complaining about this issue- speak up guys!
RTTTTed
Is there a module that would allow this system to work in our Gen 1 and 2 cars? I looked at aftermarket systems that would work for my car, except that the sensors are grossly fat and above the rim. One close call with a curb and you'll be needing to replace the sensor since they stick out so far.
Ted
Cape Coral, FL
Ted
As a matter of fact there is... dont have pricing on it yet however. It could use the same sensors as the above kit, or its own, both very similar in design to the OEM sensors.
rcl4668
Oregon, USA
Re: Solution to TPMS Sensor Woes! Multiple Wheel Set Owners READ HERE!
1. SAFER track days
2. LESS Down Time
3. NO annoying Ding
6. NO COMPROMISE!
Dan --
I would be very interested. Just so I understand, you would send me 4 TPMS sensors that I would then have my local Viper Tech install on the second rim/tire set. This would then allow me to swap the wheels and tires at will myself without any TPMS lights flashing etc. I assume that the TPMS function would still work for the second set of rims/tires (ie, still detect low pressure conditions). Thanks for your efforts on this.
Any estimate on when the product will be actually available?
/Rich
Cape Coral, FL
Dan --
/Rich
Rich-
Yes, you are exactly correct, and the TPMS function will work in all wheel sets programmed in addition to.
I will be checking availability on Monday, it is possible I could have the first few sets out the door by the end of the week.
RTTTTed
Put my name on the list of contacts for the whole system. Hopefully the module isn't too pricey. Thanks
Ted
Nader
New York
Dan I dont have the stock rims and tires on the car. Would i need to put them back on the car to get the codes? I consideration in this would be the cost of removing and re-mounting the tires. I would guess that is not cheap.
Cape Coral, FL
Hi Tom,
Nope, you dont. The original codes are still stored in the TPMS module in the car, and can be read with a DRB-III. You dont state whether your current wheels have TPMS sensors at all, but they can be re-created regardless by utilizing the original cose set that is stored in the system.
In reality, with this system, we could quite literally re-create you a set or more of TPMS sensors to work with your car- even if you dont own the sensor set and currently have no sensors at all installed in any of your wheels. The codes are still in the TPMS module, and thats all we need to mimc the original sensor set, as many times over as desired.
While this certainly would be ideal if starting with new rims and tires, installation is not too much. Most shops will charge 25-25 per wheel to dismount, re-mount and balance. To install, you dont have to completely remove either, just one side of the tire to install the sensor.
Nader
New York
Dan my HREs which are currently on the car do have sensors in them. Would I still need to take the tire off?
Cape Coral, FL
1. Do you have more than one set of wheels?
2. Are the sensors in your HRE's functioning correctly right now?
I think I am misunderstanding your situation- if your HRE's have sensors, they should be already set up to your car. if you have another set of wheels without sensors, or sensors that do not communicate correctly, then I can see your issue. Can you explain a little more?
daveat
if your dodge dealer is up to date on their tools, they have a tool that will read you the code right off the sensor without dismounting or even needing to check with the drb-3 all they would need is to have your set of tires there with the sensors installed in the rims IE. just as they came from the factory. no need to bring the car just the rims and tires
Cape Coral, FL
This is true, there is another tool that can read sensor codes. However, I think the likelyhood of dealers having a DRB-III handy would be higher than the new tool that Daveat speaks of- but in either case, they can get the job done. In any case, there should never be a reason to dismount your original programmed set, there are multiple alternatives to reading the code manually.
However, while you could certainly bring them just the rims/tires to read if they have the new style scanner, this increases the likelyhood of a mistake in code programming, as the sensor cods are not as much what we are after, as the sensors codes INSIDE your TPMS module. If by chance the wheels are incorrect, your new sensors will be wrong as well. reading it from the course will be more accurate, unless you are dead certain the wheels are programmed right.
INSOMNIAC
Europe
Dan,
Is there a way to turn off the TPMS for good?
I don’t have my original wheels and sensors anymore and the CCW wheels I have
have no sensors.
The yellow TPMS light and the ding annoys me.
Nader
New York
Bought my wheels used from another Viper owner. He had the sensors mounted in them and they worked on his car. When I installed them i had Chuck reset them with the computer and magnet but they would reset. So they do have sensors in them just never would communicate with the computer.
Cape Coral, FL
Dan,
have no sensors.
At the programming/sensor level no- though I have never tried unplugging the TPMS module, my guess is that it will fault if you do.
Cape Coral, FL
hmm... if the programming was sucessfull, you may have a bad TPMS module or dead sensor batteries.
Either way, if you can get me the codes in the TPMS module, we can write you a new set of sensors to work, even if it wont allow programming for some reason. They will have to be replaced in the tires. If the system still doesnt work, then it is the TPMS module for certain.
Nader
New York
Dan we couldnt get past the first wheel. It would not reset so I dont think there was any programming.
Cape Coral, FL
I suspect that if the sensors were installed in aftermarket wheels before they were programmed, that is the problem. when installed in te rim in aftermarket setups, they are unable to be activated by the sensor "selection" tool for programming. This would prevent your codes from being entered.
Its your call- to fix the problem, your tires will have to be broken down anyway. we can write you a set ready to rock, or you can re-program yours by breaking them down and trying first. If that still doesnt work, then there is a TPMS error, though a set of pre-programmed sensors should work if the module did work at one time. On the same point, one advantage of the new sensors is that they can be programmed wirelessly- no breaking them down in the future even to re-program them for another car.
Shandon
Northern Kentucky
I would be intersted in them Dan. Keep me posted. I have a second set or track tires I wouldn't mind not having the flashing low/tire light flash on and off for.
Cape Coral, FL
OK guys,
It looks like we have enough interest to do it at this point, and I am sure more will follow.
I will add a page on our online catalog to pre-order these sensors, and I will update this thread with a link as soon as I am done. I have to tend to a customer for a little while, so its going to take a few hours to get it up on the site.
1. RTTTTed: Full Kit
2. rcl4668
3. Nader?
4. Mike
5. Jeff
6. Shandon
7. [Your Name Here]
rcl4668
Oregon, USA
OK guys,
2. rcl4668
3. Nader?
4. Mike
5. Jeff
6. Shandon
7. [Your Name Here]
Thanks Dan. For the computer illiterate among us, can you post a link to the product on your website when its up and running? Thanks.
/Rich
Cape Coral, FL
Forgot to mention [And just updated the website];
You DO NOT need your codes yet to lock-in the pre-order price! If you have them, enter them into the "notes" box during checkout, if not, just state you will send them as soon as you can.
Thanks,
ulllose
Brunswick, Ohio
Just confirming what you typed. I bought a new set of sensors and shipped them to forgeline who installed them into my new wheels. At this point by the sounds of what you wrote above I'm not going to be able to go to the dealer and have them calibrate the new sensors????? I have yet to call the dealer because i just have not had the time but I was planning on them just calibrating the new sensors. Are you sure on this?
thanks
Cape Coral, FL
thanks
The issues depends 100% on what type of mounting system they use. If they mount like a factory sensor does in the edge of the rim with the stem protruding out, then you are OK, they can be programmed after the fact. If they mount inside the wheel onto the barrel like an HRE or an iForged type wheel does, then they cannot be programmed after the fact easily, if at all.
The issue stems from the activation tool for the sensor (basically a big magnet) which needs to be placed around the stem in order to "trip" the sensor into outputting. If the sensor is placed in a stock orientation, it can still be activated. sensors on the barrels have a very low success rate in trying to fiddle with them until they trip.
[This is actually another side benefit of the sensors I am offering- they can be reprogrammed wirelessly at a later date WITHOUT the "tool" that OEM sensors need, so orientation does not matter.]
Jeff Monheim
Hello everyone, I just took my 08 SSG coupe to the dealer and they read the tpms codes in my wheels. Now Dan from Viper Specialty has them I will be getting my new "cloned" tire pressure sensors, SOON. NO multi codes for the car to remember and read! Just the same factory codes on both sets of wheels. What are you waiting for??? You will not find a better deal anywhere!
Thanks, Dan
Cape Coral, FL
In Stock and Shipping guys! Only have a couple sets left on the shelf right now, but more are only a day or two out! I HIGHLY recommend these sensors over the Dodge Sensors in their entirety, both as a "mimic" sensor set, and as a primary. The ability for the sensor to be tripped wireless is worth its weight in gold when dealing with aftermakrt wheels and inaccessible sensor configurations.
https://www.viperspecialtyperformance.com/catalog/product_info.php?products_id=154
PS- The Viper is not the only vehicle we can program these for! Please contact us to see if any other vehicles you may own are supported!
Cape Coral, FL
Ted
Hi Ted,
There are two different systems that meet your needs. Send me a PM and I will give you the details.
