Audio Specifications
Quantico, VA
well i have no lcue what you have but if you have any amps im sure you will have either bypass them or just remove teh whole factory system and rewire everything.
what did you plan on replacing it with??
Brian Denham
North Little Rock, AR
I've not seen a 2001, but I doubt anything has changed. They say alpine on them, but I can promise you that you wont find them in any audio store. They are alpine made for chrysler. If it is like my '00 you will not be able to change out the radio without changing out the amp and vice versa. They are connected by a "special" wire which is unlike the normal rca's found in the audio market. Looks like an s-video cable found in home theater actually. The speakers are paper with tiny magnets. There are several folks on here who have upgraded. You can check out the link im my signature for what I have done to my gts. I took it to the extreme, but there is a middle ground. Email me at [email protected] with any questions you might have and I will help the best I can.
