Autolite 3923
Joseph Dell
Atlanta, GA 30338
Eric -
No idea! But good timing for this discussion... there is that other spark plug discussion going on in the General Discussion forum.
BTW - When am I going to get to see your new sled???
JD
schorvitz
Duluth, GA, USA
Hey Joseph!
My sled is getting operated on by JD Farmer. He's doing the following:
1) TSB: re-weld the frame -- takes a week :-(
2) Roe front air dam kit
3) Fluidyne radiator
4) Roe radiator hoses
5) replace door stantions (sp?) and glass since my weather stripping has mysteriously disspeared :-(
6) Replace plugs and wires.
I'm in sunny Tucson Arizona right now doing some work at the U of A. I'll be back in town on the 16th. Perhaps we can get together then?
Sean Roe
Jacksonville, FL
Hi Eric,
Generally, if you increase the power output of an engine or operate it at higher RPM levels, you go a step or two colder on the spark plug. The stock plugs are in the "hot" heat range (as most new cars are). Have someone who knows how to read plugs check the originals you pull out to see what they think (if you should change the temperature range or not). The 3923 is a plug we have used with bolt on mods and was the first one that came to mind when you asked about what plug to run.
Sean
Lee Dove
Culpeper, Va, USA
I run the 3923 Autolite plugs in mine and agree with Sean. Just be sure to use a little anti-seize when installing them...
SKY1960
