Back-up Lights Quit Working
jerryk96GTS
Darnestown, Maryland USA
Anyone else's '96 GTS back-up lights quit working? Bulbs are good and fuse is fine...only other item I believe it could be is the back-up light activation switch. Is is located on the top of the transmission at the shift lever? How do you access switch...hard to repair? Thanks for the help.
Matt M PA
Langhorne, PA USA
No doubt it;s the reverse light switch. Easy to replace too. It's on the passenger side of the trans. With my car on a lift..I was able to reach in and change them. It is behind that big panel that bolts on under the trans. Very common problem.
Probably a bad switch, but are your fuses good, not just LOOK good? Replace fuse first.....then
Put car in air. Drivers side has speed sensor and anti-reverse lockout, and dreaded skip-shift . Passenger side Trans, half way up, amidships, is the backup lite switch.
1) Unplug switch
2) Determine if power to switch, key on. (test lite)
3) If powered, Jumper across and see if backup lites come on.
4) If lites come come on, its either:
-- a bad switch, (easy) or
-- a bad connection inside the trans. (worse)
5) If no power or lites, then the fun begins. I hate electricity.....Wires contain tightly packed smoke particles trying to get out. I have proven this !
Easiest: You could just order and replace the switch....cheap at MSRP from your local dealer of $25 p/n 4626593
WARNING: COMMERCIAL MESSAGE: Or $20 from PartsRack !
Rare1
Sweden
Changed my switch too, very easy job!
Mikael
