Bad gas ??
CSXT802
Bushkill PA
I'll start this topic so that others that know more can give feed back. With gas prices high, 93-91 octane is not a fast seller. To make it worse during the winter months it's even slower. My question is what is the "shelf life" of the fuel before it starts to loose octane. Is it possible that the 93 octane fuel that we are filling our car with now has less octane than 87.? I'm picking up my viper April 8th. I'll be driving it from WI. To PA. I'll have several fuel stops along the way. This is my first Viper so I'm worried about detonation due to bad fuel. I lost a motor on one of my snowmobiles this season. I'm sure it was due to poor 93 octane fuel. As one piston lost the locating pin due to detonation. This allowed the ring to spin and catch the exhaust port. Anyone that knows 2 strokes knows what kind of damage follows.
I think the gas is all the same. Then its mixed at the nozzle. But Tom is da man for this info
And you can run regular gas in a viper. It's just a Dodge. You wont hurt anything as long as you drive normal.
Do a search for "octane" then read toms posts.
costanZo
Haverhill, MA
Congrats on the new Viper. I also got mine on April 8th, but 3 years ago. :)
I always put 93 in mine, but I believe I did get bad gas once so I just went and bought Octane Booster and didn't go to that specific gas station again. I don't know if I would recommend putting 87 regardless if it's a Dodge just in case you ever do decide to drive the car ******* occasion, which most people do. However, 91 should be fine.
The octane booster you see at gas stations and most parts stores are a total waste of money. They raise the octance. 01 not 1 point. Better off putting a gallon of acetone or xylene in a full tank
You can use 87 as long as it is not knocking/ detonating
costanZo
Haverhill, MA
Good to know.. thanks for the tip.
CSXT802
CSXT802
Bushkill PA
Seeing that I'm new to vipers. I guessing that the 2000 GTS i bought has knock sensors ecu has knock retard.
CSXT802
CSXT802
Bushkill PA
Thank you. April 8th is also the day my wife and I started dating (15 years ago). My birthday is the 10th of April. So this is gonna be the greatest birthday ever. :D
costanZo
Haverhill, MA
Wow, well April is definitely a very good month for you! Perfect time to be getting a Viper for sure. Especially since the snow is just about gone. :2tu:
dave6666
For the octane to change I'm pretty sure that there has to be evaporation going on. The lighter more volatile hydrocarbons go first. Being stored in an underground tank in the winter? Doubt you have anything to worry about.
And plum... Octane is determined before the pump nozzle. Pretty sure they are not blending that as it's being dispensed. I think the additives are blended in as the basic fuel is loaded in tank wagons for transport tho but that is back up the supply chain at dispatch.
eucharistos
Houston
the mid grade (if available) is blended at the pump
around here: reg 87; mid 90; prem 93
other places: reg 87; mid 89; prem 91
CSXT802
CSXT802
Bushkill PA
Most places in PA. It's 87, 89, 93. As long as the car has knock retard, I don't have to worry.
Tagoo
Boise, ID
Gen 2 vipers have no knock sensors. Therefore, there is no timing pulled when detonation occurs. This is why detonation is more dangerous on a viper than on many other cars.
CSXT802
CSXT802
Bushkill PA
Wow. You mean to tell me my 1988 Shelby CSXT (Dodge shadow) had more advanced engine control than my new to me viper. :(
Chuck 98 RT/10
tampa, fl USA
I'm not sure all gas is the same. Even if it was produced at the same facility. It may be spot on 99.9% of the time but there is always something that can go wrong. Maybe the QA (or QC) guy wasn't paying attention on a day a blend valve started going bad or something.
It's like beer. I drink Heineken and occasionally I get one that taste like crap, like they spilled some Budweiser in it or something. Heineken needs better QA. That's something I can't knock about Budweiser, they are consistent, it always tastes like crap.
Roy
Netherlands
Ah Heineken....you mean the cheap exportversion we don't drink!:lmao:
I like budweiser, wanna trade some of your budweisers for my cheap "peed in" export Heinekens?:2tu:
GreatWhiteKAC
