Basic PCM Flash Tuning, NO SCT NEEDED!
Cape Coral, FL
VSP now has the ability to supply, replicate, repair, flash, and modify ALL Viper ECU's from 1996-2006, and repair certain problems and conditions for 1992-1995 and 2008-2014.
One of the specific things we can do for the 2003-2006 crowd is offer very basic PCM flash tuning, without the need for a full tuning solution. For example, if you want some basic changes, such as altered fan temp target, delete Skip Shift, raise Rev Limit, alter idle parameters, turn off Power Enrichment Delay [very important for Paxton users] or delete certain check engine lights, we can offer a direct-flash solution, at a very discounted price point of 195.00, ground return shipping included!
For more advanced tuning, we of course still offer SCT Flash Tuning as always, being one of the oldest and most advanced SCT tuners.
PS- we are also BUYING damaged Viper ECU's for scrap value. If you have one you would like to get something for rather than file it in the trash can, let me know! If it has usable components, it is worth something to us, especially 1999+ ECU's.
ViperperfectionGTS
Could you please explain what this does & why its so important please?
Cape Coral, FL
Power Enrichment Delay timer keeps the engine at 14.7:1 AFR for 1.5-3.0 seconds after you go part or wide open throttle, then dumps the fuel in. It is an emissions saving feature. As you can imagine, 14.7:1 is EXTREMELY LEAN for a blower car. Also, the thermal shock of doing this abruptly and repeatedly causes the converters to fail.
Cape Coral, FL
Can you enter the VIN # and program the windows to go down when the doors are opened?
Programming the VIN/Mileage is not a problem. However, the window Smart Glass feature is NOT controlled by the PCM, it is a function of the BCM [Body Control Module]. Your VIN Mis-Match may indeed be the root cause however.
