Belanger header install
sparty116
Michigan
Ok, before everyone tells me to do a search, I already have. Extensively.
I read a bit about some problems installing the upstream O2 sensors, mainly not having enough length to work with. My question is, am I going to run into any unexpectd problems when trying to put them in the headers?
rpm9000
Texas City, Tx.
I just finished installing a set of Belangers on my 95 RT/10 and I had no problems at all. Just be sure that when you are finished to check for any wiring or hoses that might be in contact with the header tubes. One of my hoses was touching a header tube but I found it before it was damaged.
Neil - UK
ENGLAND
For practice do the drivers side first it easier !
Headers go in from the top. On the passenger side remove the spinning fan as well below the top section of the A/C box, remove about 3 bolts that hold the coolant bottle and unclip the pipes infront of it, this will allow it move slightly out of the way, giving a bit more room. This side is a lot tighter so apply lots of masking tape to your valve covers to avoid scratches
