Best place for OEM nickle and dime trim?
DougM
Lousville
Where is the best place for little stuff. I need a piece of rubber molding for the passenger window, the fog light cap for the wheel well and a few other little things. Is there a sponsor that stocks the stuff with good prices?
Asp Man
Kelowna B.C., WEStern Canada
Nickle and dime.:rolaugh: Either you haven't been around these boards very long or your pockets are very deep. There is nothing nickle and dime about these cars. You should probably mention year/model of your car, you may find you'll get a better response. Part numbers will help harvest more responses, as well. Rubber moldings are terrificaly expensive items for these cars, ie: upper door stantion molding for GTS is few hundred dollars, prices typicaly jump dramaticaly each and every year. If you need something from the dealer, get it as soon as you can.
Free advice, and nothing malicious meant by this; learn to use the search function, look around for posts from "the Wizard" and JohnB from PartsRack, etc.
Good luck and welcome aboard!
RikRok
You beat me with the nickel and dime reply, thought I was in the wrong forum for a minute.
D
DougM
Lousville
I have a '99 GTS, not an ACR. Having had various Porsche, Ferrari, NSX, Pantera etc.... I am aware of parts costs on toys. What I am looking for are small items.
In the front wheel wells, there is a round "plug" about the diameter of a tennis ball to access the fog light on each side.
On the passenger side window, I need the exterior vertical rubber piece that seals the window.
Also need a few bolt/washer combos for the bottom of the side exhaust covers.
I would hope that none of these are mode of ubotitanium. I would just rather order items like this than go to the local dealer, order the part for full retail and then go back to pick it up.
GuitarSteve
Thornhill, Ontario, Canada
From the experiences and what I've read on here, PartsRack or Chuck Tator. Never dealt with them before as I don't have a Viper, but people who have dealt with them have nothing but good things to say about them. I hope to speak with them eventually whether its just a friendly hello or when I do own a Viper, for parts.
G
grcforce327
Guest
3" Plug #4708-057 Chrysler has a habit of superceding part #'s,but this will get you to what you need!
Not sure on which weatherstrip you need ,but scroll to page 149/150 on link below.
http://www.mopar.com/pdf/viper/99sr.PDF
Give the WIZARD(Chuck T.) a call!
Viper Wizard
South Salem, NY USA
Have no fear, the "Wizard" is here!:D
3' plug #4708057 MSRP $20.95
Outter stanchion cover with weather strip [This is the only way you can get that WS]
#ME74MX3AD MSRP $400.00:omg:
Sill screws #6504580 MSRP $2.85 each
Less 20% VCA discount:cool:
914-763-3136
propsail
Connecticut USA
I'll beat Jon B to it:
"50% of all advertising is WASTED!":omg:
Call PartsRack or Tator's for 99% of all you'll ever need...at least that's my experience
~Craig
kcobean
Sterling, VA
914-763-3136
I would love to know what the engineers were thinking when they came up with that rigid strip that runs down the back of the windows on the outside. Mine is literally hanging by the rubber piece at the top where it wraps over the top of the stanchion. I've tried contacting cementing it back in place, but no luck.
Asp Man
I didn't mean to sound like a jackaxe, and I hate to say I told you so...$400 is not nickle or dime.:(
The sill screws may be missing for a reason, make sure when replacing them that the holes are not striped out, they are only sheet metal screws after all, and they'll only "take" a couple of times. The last thing you want is a screw in your rear tire.
On the up side, the plug is only $20.
JonB
Legacy\Supporting Vendor
Columbia River Gorge
Or, half of All the people who see advertsing are wasted...
Now, THAT'S Funny !!!
WELCOME TO THE WACKY WORLD OF VIPERS.......
PS: If you are a bit more specific on the rubber weatherstrip description, the horizontal piece atop the door is also 'nickel-dime' vs the vertical tracks quoted. So is the fender well plug cheap, that Chuck ID'd for you.
But please consider: why ask for a better price on nickel-dime stuff? Isn't that 'nickel and diming' ? Chuck saved you the research work, just pay the $20 ! [The part is FREE, but is'nt Chuck's help worth $20 in time saved to get the right item?]
And As some of our regular customer's can attest, the true 'nickel&dime' stuff is sometimes no-charge from us.....
D
DougM
Lousville
Actually, a member here PM'd me and is sending a set of the plugs for the cost of shipping. They are probably used, but I don't care. Regarding the trim piece, I have it the part number saved. It is just not worth the $ at this moment.
For the future, I will use the board sponsors for my needs, now that I know who they are.
GTS Bruce
Orchard Park,NY,USA
I might try to glue it in place with 3M super weatherstrip adhesive. Nothing I have ever glued with this stuff has come apart automotive or one of the wife's nick nacks's. Oops don't tell ! Comes in black or yellow but if you work neat it doesn't show. Have seen rubber bump stops attached to hot rod frames etc with nothing more than this glue and they stay put. Have fun getting it off you're hands or any other place you don't want it. GTS Bruce
Asp Man
That might work for awhile, but the real problem with that weatherstrip is that it is too short for the window. When the glass is at the top it interferes with the piece in question. If you manage to get it glued down, and put the window all the way up, over time it would tear the strip where it folds over the top edge of the glass.
I understand that the replacement has been re-engineered to fix that problem (read it here some time ago). I'm sure the Wizard would know more about that.
v10kingsnake
south jersey
I glued mine a few years ago and haven't had an issue since. Can't remember which kind but it held great.
mtoce1
