Best place to pick up ign. power near PCM?
TS6
Hooking up my shift light and figured it would be easier to just wire everything right there. Anyone know which wire to grab?
FE 065
MI
I pick it up under the lower steering column cover myself.. (the 2pc cover behind the steering wheel)
:cool:
T
TS6
Isn't the PDC (Power Distribution Center) right above the PCM? 12V+ a-plenty?
You mean the fuse/relay box, or the stud where all the positive cables are? Because that stud is hot all the time, don't wanna kill the battery.
T
TS6
Dammit, I keep forgetting that!
Its a 97 GTS.
Dan Cragin
LA, CA
The window washer pump gets 12V key on power.
