Bolt On Goodies
JohnnyViper
Massachusetts
1997 GTS
Based on my search 3.55 gears are a great mod and have been convinced to buy from members threads, if I find some time in my busy week will be placing an order before Friday. Over the winter I’m building up my Viper with bolt on goodies. Since I took ownership 6 months ago I have done smooth tubes, high flow filters, b&m short throw shifter with MGW knob, HID headlights and fogs, 2002 door handles, rear muffler delete and 2010 SRT 6 Spoke Rims with Nitto Invo tires. Before next spring I will have installed High Flow Cats with dynomax 24222 mufflers, 3.55 gears, lowering caps, EBC Red Brake Pads, slotted and dimpled rotors and Toms Rear Calipers, upgraded engine and transmission mounts
My questions for members is:
1) What other mods would you recommend short of an engine rebuild, FI, and headers?
2) For those that have a similar set up and with 3.55s what do you think the best 0-60 and quarter mile times would be with a very polished driver :drive:
RevHeat
San Antonio, Texas
You do not mention anything about maintaince, but I would do the following:
1) Motor mounts.
2) Get the power steering cap vent.
3) Upgrade P/S Pulley and Bracket.
4) Pin crank bolt.
J
JohnnyViper
Massachusetts
Those are great suggestions; I forgot to mention I will be upgrading my engine and transmission mounts also
97snk
I've the roe billet PS bracket in classifieds if you are interested. How hard was the 02 door handle mod? Could you please elaborate on that mod?
J
JohnnyViper
Massachusetts
it was a pain in the ass and required a whole lot of cutting of a perfectly good door, but it was completely worth it! there is a write up on how to do it in the members section, it was very helpful in the process but remember this tip cut in small increments and keep retesting the fit to avoid a expensive mistake, however I really recommend this upgrade!
J
JohnnyViper
Massachusetts
plum what I have listed to be done by spring will be it unless there is a common suggestion to do something in addition, i am planning on picking up a 2012 so i will stop short of doing a engine build, supercharger, or headers do to the fact i'm keeping the exhaust system 2.5 inch from the dynomax muffler back, nitrous is a strong consideration for summer
J
JohnnyViper
Massachusetts
you know before this thread i never knew about this mod! it will be done before spring and its not a bad price! Thanks Rev! :2tu:
keep the cap from coming loose and letting oil get on the exhaust. saving your car from fire
VenomXX
