Brake fluid Question
22YRSOLD
When changing rotors and pads is it recommended to change brake fluid??
Ulysses
San Diego, CA. USA
If it's a street car, change the fluid when it starts to get dark. You will usually have a few fluid changes in between pad changes. If you haven't done the fluid change in a while, yeah, you should change it after the pad and rotor swap.
Purdue_Boiler_Viper
Indy
Ulysses is right. Decent brake fluid is cheap. **** out the old, (Turkey baster) and replace with good new fluid. Easy.
22YRSOLD
my brake fluid is very clean. looked like brand new motor oil, im guessing its still stock. u think i still need to change it
22YRSOLD
lol. hahaha, no its the stock one. car only has 23k miles.
Purdue_Boiler_Viper
Indy
23k on a Viper is not low miles. Mine has 5k. 2001. Very good brake fluid is cheap. I'd change it just so you know when new fluid was substituted. Just my humble opinion.
ViperRay
Topeka, KS
If you change the brake fluid in the reservoir you must also bleed the fluid at each wheel (till clear) otherwise you still have the old fluid in the lines and calipers.
Old fluid has a lower boiling point and your brakes will fade more easily.
Slntnoze82
