Broken Engine Mount + JonB
SlowCreamPuff
Bellevue, WA USA
I discovered that I have a broken engine mount (driver side).
Oh well... In the past 9 months, I babied the car for 20,000 miles.
How can it happen?
So, I called JonB on a Saturday of a long weekend. He was glad to help me on the phone!! He also knew that's what it was too.
To make sure, I also talked to Cam, our local Viper mechanic. He was also glad to help!! He also knew that's what it was...
What a great Viper community around here.
JonB
Legacy\Supporting Vendor
Columbia River Gorge
<BLOCKQUOTE><font size="1" face="Verdana, Arial">quote:</font><HR>Originally posted by Jim Sullivan:
What were the signs that you had a broken engine mount?
<HR></BLOCKQUOTE>
Michael's shifter was moving significantly to the right under load...not staying in place as before.
Other symptoms can be annoying sidesill noises/rattles on the left side.
Ron
Indianapolis
<FONT face="Comic Sans MS">Question?
Hypothetically, lets assume a Viper tech removes the transmission while the car is on a lift and does NOT support the rear of the engine, would that stress the mounts (Y/N) and lead to premature failure?</FONT f>
JonB
<BLOCKQUOTE><font size="1" face="Verdana, Arial">quote:</font><HR>Originally posted by Ron:
<HR></BLOCKQUOTE>
Since the mount is suppposed to withstand the weight of the motor AND the 500 lbs of torque, I would say YES it would indeed 'stress the mounts' but NO, that dumb oversight would NOT lead to premature failure. Also a Bad idea to have the exhaust system bearing the weight of an unsupported motor.....
Ron
Indianapolis
<FONT face="Comic Sans MS">It's amazing how some (I daresay most) professional mechanics, even with the added training of Viper school still don't get it.
It's common sense not to hang the motor on 2 mounts, it's common sense to replace the pressure plate in exactly the same position relative to the flywheel upon re-installation, (as the manual states), etc., yet I have been unable to find any tech that not only has that degree of common sense, but who also doesn't get offended when I request that level of consideration. And these are the guys that are going to reassemble my suspension.
I supposed we're cursed in that we care.....
Thanks Jon for the info</FONT f>
