Broken Window Clip Fix
OVERBOOST
Panama City, FL
This is for the people that have the broken window clip.
Save some money and do it yourself. I got the little clip from PartsRack.
"Thanks JonB":2tu:
So first take off the door handle trim piece.
Then take off the door panel. Top arrow is a door clip. The bottom is a screw.
There is also a screw in front of the door panel. Take out the speaker and unplug it from inside the door.
The window should be halfway up. Now unbolt the track at the top and one underneath.
Pull out the track
Bend the little clips back and remove the adjuster.
Pull the broken clip off and put the new one on.
Bottom wire first.
Reinstall the track. Now you can push the window away from the track so that the prong goes into the clip.
Slide the retainer from the right side of the track.
Make sure that the retainer goes through the groves of the prong.
This is what it should look like.
Now just reinstall in reverse and your done.
xeng yang
