Can't find the post about the door wire harness on a 2000 Viper..being bad.
Qualitywires.com
Louisville, KY
Can\'t find the post about the door wire harness on a 2000 Viper..being bad.
Doesn anyone recall the wiring on the door of a 2000 Viper going bad or breaking? I remember hearing that the 2000 Vipers had issues with the door wiring harness being too short or breaking. Can someone enlighten me?
Thanks!
Joseph Dell
Atlanta, GA 30338
Re: Can\'t find the post about the door wire harness on a 2000 Viper..being
they all do. the speaker and/or the door lock will break. shop manual has the wiring schematic. if you need it, let me know...
JD
Blue Pilot
N.E. Ohio, US
Re: Can\'t find the post about the door wire harness on a 2000 Viper..being bad.
Ab, I had this problem about two years ago on my 2000 and had the wiring harness replaced under my extended warranty. It had chaffed at the rubber grommet where the wiring enters at the body. We found it when my outside electric door popper quit working, and found several wires chaffed.
Hope this helps.
Q
Qualitywires.com
Louisville, KY
Thanks guys!
Blue Pilot when you pulled the grommet back, you saw the wires that were chafted or did you have trace it down?
kodiakleather
