Can't stand the heat
Ronald L. Cypher
Butler, PA
Can\'t stand the heat
I have the SRT10. The cabin is so unconfortable. I took it to my dealer today to test the A/C. They said it was working properly. They told me the refrigerant they use on the SRT is different from the old viper because of federal laws. Does anyone have any aftermarket remedies for the heat?? <font color="blue"> </font> <font color="blue"> </font>
Russ Oasis
Miami, FL USA
Re: Can\'t stand the heat
I live in Miami where it is rarely less than 90 in the summer. I find the AC to be adequate to fight off the heat. Are you sure you're using the right settings? If so, take it to another dealer unless you're positive that the one you took it to knows what they're doing.
SylvanSRT
Sylvan Lake, MI, USA
its been almost 80 plus high humidity and w/ the a/c set on the max flr/vent setting seems to work well even w/ the top down.
Phoenix SRT
When it hits 100 here in Phoenix, the a/c keeps up fairly well (nothing to spare, though) if the top and windows are up. With the top down, the car is uncomfortable even at 90 because of all the heat transmitted from the footwell and swirling into the cockpit from under the the car and from the hood and side vents. I pretty much don't drive the car if the temp is over 90 because it's too hot with the top down and there isn't much point to driving it with the top up.
