Catch can help please
sssammm
United Kingdom
Ok, I have 2 outlets on the rear of my 2 valve covers, the left bank pipe
goes directly to the catch can, the right bank pipe goes up into
the inlet manifold just behind the throttle body, which defeats
the object of having the can, which is always empty.
Should I plug the hole under the manifold and route the
right bank pipe also directly to the can? seems logical to me?
but would like clarification that it ok to plug the manifold hole
Ta Sam
FLX109
Massachusetts
Usually both valve cover outlet hoses should lead together connecting at a T and then connect with a hose to the inlet of the catch can and from the catch can outlet to the intake filter housing connect.
sssammm
United Kingdom
"from the catch can outlet to the intake filter housing connect. "
How about to the inlet underneath the inlet manifold?
zeeshan_k24
