Changing Tranny Fluid
billz
Hello, I'm changing my tranny fluid for the first time. I have a 96 GTS and was wondering if the pan under the tranny has to come out to get to the drain plug? Any help would greatly be appreciated.
Joseph Dell
Atlanta, GA 30338
it doesn't _have_ to but you really want to remove it. 10 or 12 15mm bolts w/ an impact wrench takes all of, what, 45 seconds? do it for sure.
JD
Yes....15mm socket on shield's bolts (10)..use 3/8" square pipe plug or 3/8" square drive on drain plug on right near tail (re-torque to 28 ft-lbs)...use same 3/8" sq.drive on fill plug on left near tail(re-torque to 20 ft-lbs).
B
billz
Thanks for the responses. I pulled the cover and the rest was easy...
gavinpeng92
