Viper Blade
2000 GTS I idled the car in my driveway to operating temperature to do a proper coolant check. Before doing this I had removed my airfilters and forward box to clean and oil them. I let the car idle without the filters or forward box in place until it was at normal temp. I then checked my coolant and installed my filters and assembled the box. I have a check engine light on. Did that occur because of having the box open when running? I did not unplug the air temp sensor in the filter box.
I tried to perform the on off on off on trick to see the codes and it didn't work. I guess I will go see if O Riellys can check the code but I'm curious if it was just the airbox being open.
