Clicking noise
Dan Aseere
Mason, Ohio USA
94 rt/10 When I turn on the key I hear the fuel pump but I also hear a loud clicking noise in the dashboard for a few seconds. Does anyone know what this is.? My 97 GTS does not do this. Thanks in advance
benson8708
I was going to help you until you said you have TWO VIPERS....then my jealosy took over and I wrote this!
bluesrt
could be the hot and cold door servo needs to be calibrated- as for the heat and cool box in the dash...:confused:blend door
NHL2133
Greeley, Colorado
Well, if I knew for a fact that you were an old guy, I'd tease you and say your blinker is on. Since I'm not aware of your age, I'll just let you decide if this post applies. :D
jdeft1
Metropolis
Clicking like a turn signal? One click, multiple clicks??
Have an after-market radio?... how about a stuck CD in it trying to come out or a stuck tape if it's original? Does it happen every time? Have any added gizmos, lights etc.. (I'm thinking added relay)...:dunno::dunno::dunno:
D
Dan Aseere
Mason, Ohio USA
I do have a cut off battery switch I turn off each time I put her away. It does not have any other mods. It does it each time I start it after I turn on the battery switch.
NHL2133
Greeley, Colorado
Would a guy with 2 vipers not know if his blinker is on....Give me a break!
I was just giving you a hard time. But along those lines, is it possible your blinker relay is going bad? I had a girlfriend with a bad blinker relay that would click almost constantly after using the blinker once. :dunno:
BarryLB
