clutch for 93 RT10
93Snake
Hi, I need help finding an aftermarket clutch and associated assemblies for my 93 RT10. Recently purchased, 40 K miles and original is smoked. Sunday Driver..
any help would be greatly appreciated, parts, manufactures, techniques, pitfalls, associated steps to avoid or not forget etc...
t
thanks much
99 R/T 10
Enterprise, AL USA
Why not get a stock replacement? It is a stout piece and will do the job. Call Chuck Tator, Sean Roe or any other of the fine website supporters :2tu:
Cris
Check the archives. Many have used the set that sells on Ebay. Worked for me.
93Snake
thanks for your responses. I hear about aluminum flywheels, clutches that can handle hp upgrades, etc. just trying to leverage off all the knowledge in the VCA rather than make an obvious mistake. Could you guys recommend brand names, parts, advantages of new vs used, prices??? thanks again, mike
Cris
The Ebay clutch is the stock Luk clutch assy, without the dealer tax.
JiPi
Geneva, Switzerland
That's what the Viper Wizard said on a previous post:
<< 92-05 Viper clutchs are the same #4848708AC it is made by LUK.
Don't buy it from the Dealer! Did I just say that? Yes I did!
Get the clutch from your local parts store for under $400!! LUK #05-088 and you will also get a throw-out bearing with the LUK kit and you don't get it with DC's kit! To get a T/O bearing from DC, you'll have to buy a slave cyl for $300!
That's where I get mine from! >>
93Snake
OK Gents, first; thank you all for your insight. There is a good chance I will upgrade pwr to close to 500 ponies, thus I am really wanting a "Heavier duty" clutch etc for the replacement. I have seen a clutch from [******] for 1000 bucks (center force), aluminum flywheel (900 bucks) [******] again; Archer Racing offers a Kevlar product that seems reasonble with flywheel (aluminum) also, seemingly reasonably priced. The [******] options..toooo much for me, the 450 price of Archer Racing seems about right....One last question, do I need to replace the slave cylinder??? My understanding is that I need to replace both the slave and the throwout bearing, as it is one piece (dealer provided or Dodge supplied only.) OR can you buy a throwout separately??? Any last comments welcomed as I make my first repair/upgrade to an otherwise bone stock black 93. thanks much guys/gals Mike
RedEnuf93
Lancaster, PA
I have 607HP and 768TQ with stock clutch. Does not slip and has 41.000 miles on it. I see no reason to "upgrade" to a more expensive unit.
Cris
The Luk clutch is an upgrade of sorts for a '93. It is the same as used in Gen II's (1/4" larger disk). Works well with the original flywheel so a change is not required. Should be good to go for 500hp. More than 550 hp I would start looking for an upgrade.
No members online now.
JpKL
