Clutch?
Indiana
Las Vegas
My 2001 GTS is a driver and will be street use only with stock power. What clutch should I go with? Better options than stock?
VIPER GTSR 91
Spring, Texas
The stock clutch is bullitt proof. My old 99 GTS was a driver and track car with 700 hp and the oem clutch never faltered. With stock power you will be fine for a long time.
JonB
Legacy\Supporting Vendor
Columbia River Gorge
Can I just turn and reuse my flywheel no problem?
The OEM flywheel is NOT resurfacable per Dodge. But if it has been street-driven and not abused, you could be OK.
But a lightweight flywheel from $369+ is faster acceleration and better braking and NO additional labor when you are doing the clutch....too good to pass up?
The "better clutch" options may be rated at 900-1100 lbs torque, even weight 8 lbs less, and have better pedal action, but still cost more.....money maybe not well-spent on a street car
sniper1
BOSQUE FARMS, NM
I-Force Clutch kits are an excellent upgrade if you do decide to go aftermarket. Double the cost of stock kits but worth it.
Chuck 98 RT/10
tampa, fl USA
Go chromoly. Got mine from JonB.
:usa:
You didn't happen to weigh it before installing did you? This discussion came up recently and there wasn't a resolution.
Numbers are from memory.
43lbs Stock flywheel
33lbs DCPerformance chromoly flywheel (website says 10lbs less than stock)
20lbs JonB chromoly flywheel
18lbs Fidenza aluminum flywheel
Can we get pics of the JonB and Cragin chromolys so we can compare? Or is somebody's facts off by a few pounds?
PhilC
Jackson, NJ, USA
I'm pretty sure the one JonB sells is the Cragin one (at least the one I just purchased from jon came from DCP)
RobZilla
Jacksonville, FL USA
Sorry Chuck, I didnt even think to put it on a bathroom scale before installing. From memory it wasnt exceptionally light, but it was lighter than stock by a few pounds. Enough to notice just by picking it up.
:usa:
Camfab
SoCal
Save your money, the stock clutch is an excellent part. If you're considering dragracing or just spirited street driving, stick with the stock flywheel. If your interested in roadracing, a lighter flywheel may be of benefit.
xeng yang
