Comp Coupe Cam Installation
Cape Coral, FL
I am curious if anyone here has any pointers on Comp Coupe Cam Installation here. I am in the process of degreeing one, but I would like to hear from anyone has has done a couple before, and what the results of various degrees were.
When the cam is installed with the OEM timing set, it comes out to 124 degrees Intake Centerline ATDC. The Cam calls for 117 degrees, and if my quick calculations were correct, putting it in offset by one tooth will put it dead onto 117. However, I would like to hear from anyone who may have installed them at other centerlines, and what the results were.
Thanks for any info.
