Comp Coupe Oil Pan with weld in the middle of it.
Michael Hatch
Tampa,Fl. USA
First, when you buy a swinging arm oil pickup, is the comp Coupe pan required with it or can you use the stock pan? I had this installed early 06 but now not sure if I bought the pan and pickup or just the pickup.
Does a new Comp Coupe pan have a weld in the middle of it? when installing S/S brakelines last week,
this was noticed. Right in the center of the pan about 5 inches long.
2002_Viper_GTS_ACR
Charlotte, North Carolina
You must have the comp coupe oil pan to work with the swing arm, they are BOTH required for the install.
Next, yes the weld means you have the comp coupe oil pan. Its a very WIDE v like weld.
Jon
miwr
