Covertible Top Latch Issue
Jabbate
Glastonbury CT
Is the convertible top latch suppose to remain in the unlatched position after removing convertible top? Mine
I believe used too and now it wont stay locked in the unlatched position. My dealer says its suppose to be like this. Either im nuts or he is? Help
Venomiss
Guest
I found this in a search, have you called anyone else-chuck Tator-maybe he can help you.
SEE IF THIS HELPS:
5029168AB 1 27 HANDLE AND LATCH, Folding Top
6507337AA 4 BOLT, M6x25, Latch Attaching
5029157AB 2 27 PIN, Dowel, Folding Top Locator
4865936AC 1 27 LATCH AND BASE, Folding Top
4865781AA 12 STUD PLATE, Convertible Top Tack Strip
Mounting
5029082AC 1 27 COVER, Folding Top
RETAINER, Weatherstrip
4865570AC 1 27 Folding Top Front Side Rail, Right
4865571AC 1 27 Folding Top Front Side Rail, Left
4865572AC 1 27 Top Rear Side Rail, Right
4865573AC 1 27 Top Rear Side Rail, Left
5086733AA 1 CLIP, Latch
5093071AA 2 CABLE, Topcover Tension
SIDE RAIL, Folding Top
5029134AC 1 27 Linkage, Right
5029135AC 1 27 Linkage, Left
5029195AA 8 BUSHING, Pivot
6507761AA 2 27 SCREW
5029080AB 1 27 STAYPAD ASSEMBLY, Folding Top, With
Rivets
5029133AB 1 27 PANEL, Headliner
5029167AC 1 27 BOW, Folding Top, Number 2, Includes
Front Header
5029130AA 1 BOW, Folding Top, Number 3
5029131AA 1 BOW, Folding Top, Number 4
5029079AB 1 27 MOLDING, Folding Top
5029076AB 1 27 PANEL, Tackstrip Support
TACKSTRIP, Beltline Bridge
5029266AB 1 27 Right
5029267AB 1 27 Left
5029077AA 1 TACKSTRIP, Beltline Center
TACKSTRIP, Beltline Outer
5029084AB 1 27 Right
5029085AB 1 27 Left
5029215AB 1 27 COVER KIT, Tack Strip, Covers Item 21
6036444AA 8 SCREW, .25-20
SCREW
6507763AA 12 27 Top Seal Retainer
27 Top Seal Compression Panel
27 Cloth Support Panel
5029081AB 1 27 BACKLITE
DODGE VIPER (ZB)
6507762AA 2 27 SCREW
DODGE VIPER (ZB)
5256749 2 BUMPER, Deck Lid Adjuster
6101968 2 NUT, M6x1.00, Downstack Bumper and
Latch
6503351 4 SCREW AND WASHER, Hex Head,
M8x1.25x35, Folding Top Attaching
4854372AA 2 BRACKET
6102050AA 4 SCREW, Hex Flange Head, M6.3 x 1.81
x 15.00, Bracket Attaching
6102238AA 14 NUT, M6x1
DODGE VIPER (ZB)
PaulP
my 05 front latch used to stay down after opened now i have to pull front latch back then hold the hook down then close the latch , any idea how i can fix this, there must be a spring thats off or something too keep hook down when opened ?? any help
miwr
