Rear differential replacement issues!!
jacobchristensen
Arizona
Has anyone replaced their viper rear differential with an aftermarket one from The Drive Shaft Shop? I have had to send mine back twice now to the shop because it’s making noise. The first time was the pinion bearing making a horrible wine which they told me would quiet down after awhile. I sent it back for them to fix and got it back with the pinion bearing still making noise just not as loud. Again they told me to just complete the break in period so I had a local Viper mechanic ride along and said he’s never heard a rear differential sound like that and to stop driving on it immediately and return to the shop to fix it. It’s been over six months now I’ve been dealing with them “trying” to fix it. I am supposed to receive it back in the next week or so to install it for the third time and very frustrated with the whole ordeal. Anyone else having or had issues with this shop???
Dan-o
Spokane, Wa
Could be gear whine because pinion depth is off. Did you check the pattern? Did they put new bearings in? Pinion preload could be off as well. It takes a lot of skill and attention to detail to set up a rear end properly. I’d find another shop
Dan Cragin
LA, CA
The setup on Viper differentials is a bit of a learned thing, but most good gear shops should be able to setup a rear end to not much noise.
A noisy diff does not really mean there is a issue or its going to fail. On the Viper gear noise is a common complaint as the rear end is mounted
directly to the frame and any gear whine is directed right into the cockpit, less so in a RT/10.
Unitrax in Ca has done over 200 Viper differentials for my past customers over the years and is a good resource.
Steve M
Dayton, OH
Given my experience with their customer service associated with their aftermarket axles, I'd never even think about doing business with them again.
They don't give two flying hoots about their customers, nor the quality of their products. If the rear end is making that much noise from the get-go, I'd suspect a setup issue, and that's all on them. And if it's their fault, they'll never admit it.
When you get tired of them, highly recommend finding another shop to go through it that knows what they are doing, preferably local to you, and preferably one that stands behind their work. Differential setup is tedious, and is why most shops will want nothing to do with it.
Old School
North Alabama
I agree with this. There are several 4x4 Jeep shops in my area with tons of experience setting up the Dana 44, it's a big part of their business.
Cape Coral, FL
Its a pain in the ass I know, but I have no problem setting up differentials via mail order if someone wants. I have G3/4/5 case cores on the shelf, and can drop in a Wavetrac, Quaife or otherwise.
Mail you out a new one, send back your old one. Shipping will **** as it really should go freight, but its possible.
Just did a Wavetrac a few months ago for a customer down here. Have been avoiding the mechanical end for a good while, but I am slowly getting my equipment down here in FL, so these are doable again.
Have done more Viper diffs over the years than I care to remember. They aren't difficult so much as tedious.
