Crower: Camshafts + 1.7 Rocker
Martin D
Dunwoody, GA USA
You can do alot better then either of those grinds. What else are you doing to the car?? Heads and bigger valves?
Regards,
99 R/T 10
Enterprise, AL USA
Go with Arrow rockers before you go with crowers! Crowers have been known to shift and cause major damage. Arrows are shaft mounted and do not have this problem. Check with Sean Roe.
Vipermed 97.01
Tampa Fl. USA
You are correct that Arrow are much better than crower but they are not shaft mounted,they use a guide pin between rockers,T&D/Mopars are shaft mounted.If you are not doing alot of consistant high RPM driving then Arrows will work great and they are more affordable than T&Ds.Alot of people have had trouble free operation from Crowers but we have seen first hand damage to motors from these rockers with professional installation.They also contradict themselfs by saying on there site that they will allow for Revving over 6200RPM but on the box you recieve them in there is a big red warning sticker stating do not rev above 5600RPMs.
Bad_Byte
Corpus Christi Tx
I have a set of Arrow's I'll let go of for a good price.
I believe the retail for $600 I'll take $400.
Snakester
Morgan Hill
I installed the Crower RRs and they have run fine for almost 2 years now, but if I could have bought the Arrow RRs for $400 I would have snapped them up in a heartbeat.
-Dean.
cs83
