Hello everyone. I am new to the club. I live in North Dakota and purchased a '98 RT/10 in Wisconsin a couple weeks ago from a dealership. They told me the driver's window had an issue and they ordered a new regulator mechanism and had it shipped to my home. For the past two weeks I have been reading all the window problem posts and it appears the little plastic guide piece is usually the culprit. Yesterday my new regulator arrived. Tonight I took off the door panel. The window is in the up position and wouldn't move either way. Upon inspection I could see the plastic piece was broken. My son and I worked on it a bit and we were able to get the window down far enough to pull the little metal clip out of the plastic piece. My problem is, how do you get the glass to move out far enough to get it to disengage from the plastic guide. There is obviously a pin on the window that fits into the plastic guide and the metal clip holds it in place. I can't move the regulator bar up to remove the unit as long as it's attached to the window. I have read many posts here about the window problems, but haven't seen a description of how to get the window to release from the guide. Also, is the guide the only place that the window is connected to the regulator unit? Does the stanchion have to be removed to wiggle the window loose from the guide? Can someone help please?
