Differences in '03 through '06.........
Don Hiltz
Rainbow City, Alabama
Differences in \'03 through \'06.........
The previous owner of my '03 had red brake calipers installed. Yesterday, my wife was looking at an advertisement for an '06 convertible and remarked that there's no obvious difference between it and ours.
My question: Are there any obvious differences between these 4 models, assuming all are convertibles????
Don
Y2K5SRT
Overland Park, KS
Re: Differences in \'03 through \'06.........
There is a list somewhere, but among the changes that I can think of off hand:
Brake caliper colors
Trunk carpet (not in 2003)
Convertible boot (not in 2003)
Different gauges
Different radio
Different valve covers (breather moved to the front)
Knock sensors (2005+)
Optional wheels (2006)
Different colors in different years (but not much)
That's just a few things I can come up with for now. I am sure there will be many others added to this thread...
Y2K5SRT
Overland Park, KS
What changed with the gages?
'03 on the left, '05 on the right:
YoungDoc
Palatine, IL
I'm shopping around for a viper and plan to buy in june or july... I too would like to know the differences.. thanks guys...
SnakeEye
Austin, TX
Good question but you may wish to try doing a search on this topic as it's already been covered in some detail.
SRTRICKY
Canada
while we have this pick posted where does your guy's needle sit when your driving normal? (cruising??) Mine sits extly between 240 and 300 is somethign wrong with that?
luc
Paso Robles CA
Something must be wrong with your gauge or sender, no way that the "normal" oil temperature is 270* when crusing.
Luc.00GTS
SRTRICKY
Canada
Luc.00GTS
time for an appointment with dodge then glad I checked here...what do you guys think is wrong with it? just the oil changed too
Cris
Once your car is warm, and assuming you are not on the track, the oil temp should track right with the coolant temp. Therefore you should see right around 200 most of the time.
luc
Paso Robles CA
Gauges usually don't go bad, especially when the problem is only with one, so, my guess will be the sender or the electrical connection at the sender.
Most senders work the same way by changing the resistance (ohms), usually of the ground side, as the temperature/pressure/level change.
B4 taking it to the dealer, there is a simple test that you can do, unplug the electrical connector to the sender and, with the ignition on but the engine not runing, ground the connector (meaning the metal pin inside the connector must contact the engine block or frame).
That should send the gauge to the max reading, if it does you can be 99.99% sure that the problem is with the sender.
Luc.
00GTS
Vipermann
Texas
So all 2005s have knock sensors? I didn't realize that my 2005 had a knock sensor ...
Cape Coral, FL
There is a MUCH easier way of testing the entire gauge pod in the SRT-10s.
With the key OFF, press the trip odometer button. Turn the key Forward (ON) while holding this button, release button after 2 seconds. The gauge pack will go into self diagnosis mode. Try it... its awesome actually!
PS- Gauge changes were a 2004 change.
rschiltz
Houston, TX
If a person is shopping for a SRT, ss there one year that would be considered a better year based on options or changes?
Cape Coral, FL
-03 has the strongest rods...but the pistons are the weak link...so not a big deal really. Weaker rear diff pin than later MY's. different gauges, sleep mode, etc from later MY's.
-04 has all of the running changes except knock sensors and the new valve cover breather location... can be added/changed.
-05/06 has a new style RBQ radio, but they are both functionally equivalent... plug and play with older RBQ's and RB1's as well.
INSOMNIAC
Europe
The 03 - 05 Vipers are advertised as 500 HP.
The 06 Vipers are advertised as 510 HP.
Viper X
HP measurement test methodology change caused 500 to equal 510. No other engine changes.
