Door popper stuck.
2000GTS
Miami, FL
The other day as I was getting out of my 2000 GTS and the door popper got stuck. Now I can't open the door from the outside. The black button seems to be stuck in. I tried prying it back out but I don't want to scratch it up.
Are these easy to remove? Can it be switched with the passenger side temporarily?
Bill
4207henri
I just sprayed some silcone spray in mine over a year ago when it was stuck....havnt had a problem since, just spray a little bit.
Blue Pilot
N.E. Ohio, US
My button stuck when my wiring harness went bad. It was stuck all the way in, and the door would not open from the outside or inside. I had to use the release latch to get in.
good luck
zeeshan_k24
