Door Popper Won't Open Doors on 93 Viper!!! UGHHHHHHHHHHHHH
Ivory
Madison, WI
Door Popper Won\'t Open Doors on 93 Viper!!! UGHHHHHHHHHHHHH
Installed 15# door popers as directed in the illustrated upgrades.
Got power to the poppers
Good solid ground
working poppers via the remote
But when the popper pulls back on the pull point, the pull point has about an inch of slack in the mechanism befor opening the door. I believe the popper either does not have the pull distance or the strength to open the door. Any advice would be welcomed. This is a '93 car and the shoulder harness assembly does not come out to mount the popper. The pull point does not have a factory location to mount the pull wire. I'm currently just pulling on the mechanism.
At this point, I can't figure it out and I think I've mounted the gosh D*&# things incorrectly.
This upgrade is on the 12th hour!
99 R/T 10
Enterprise, AL USA
Re: Door Popper Won\'t Open Doors on 93 Viper!!! UGHHHHHHHHHHHHH
I did my 96 mounting the popper on the back of the box where the lower shoulder harness reel is. Could be it is just at a bad angle, good luck with it tomorrow.
And just in case, print this out
I
Ivory
Madison, WI
Sorry but no pull point on the bottom of the mechanism to attach to. Only a single pull point where the door handle is currently attached. Any suggestions?
ruckdr
Renton, WA USA
Ivory and I have been solving the installation problem. It must be mounted like 96 R/T 10 suggested. Should now be resolved.
Don Ruckman RUCKDR
Mando9595
