Drags at Carlsbad, Ca. this Sunday...
2charmed
Chula Vista, CA USA
Kevin,
You'll have a bunch of fun!!!
The helmet requirement is a DOT rated helmet I think? They were'nt checking when I went last time so long as you had one.
You must also have long pants on. You'll want flat bottomed well fitting shoes also. You must have a hard top or GTS if you run
below 13. seconds I think.
You'll be able to run several times so don't show up with an
empty tank. (you don't want a full tank either due to wieght)
Good luck,
Steve
IMSOSLO
Ramona, California
Ulysses,
All you have to do is rev. to to around 5000 and drop the clutch. :)By the way did I mention I want to run against you your first run. I figure once you get over the butterflys and get the hang of it I won't stand a chance.
Ken
brett
scottsdale, az
<BLOCKQUOTE><font size="1" face="Verdana, Arial">quote:</font><HR>Originally posted by Kevin Slatnick:
I heard that a snell 2000 rating is required for the helmet. Does anyone check?
<HR></BLOCKQUOTE>
Snell 95
roadking40
