Driver window will not go up. (Replaced Regulator)
ChadB
Atlanta Ga
My driver window would intermittently go up, had to wiggle the switch and it would finally go up. Well it finally stopped working, I thought it was the switch since it would roll down fine but would not come up. I checked all fuses and relays then replaced the switch, door control module, ohmed out the wires from the switch to the door control module and to the regulator and replaced the regulator. The window will not roll up and I am lost as to what it could be now.
Any help would be appreciated.
Very Common for Gen II's to be Window switch. Put a meter on the Motor to check for Voltage on both going up and down.
C
ChadB
Atlanta Ga
I replaced the switch first and then checked all the wiring, it still did not work that led me to replace the door control module since I did not hear it clicking when I pressed the switch.
C
ChadB
Atlanta Ga
It won’t move at all and I didn’t have that issue when I replaced the passenger regulator.
How do you do this?
Check the owners manual or someone here will chime in but that is assuming a working system. Usually it is hold the switch up until it closes and hold it for x amount of seconds, repeat for the down movement.
vgregv
