Drivers Door Won't Stay Open
SYNFULL
Bucks Co, Pa
Drivers Door Won\'t Stay Open
Do I need to replace the hinge? There isn't any type of adjustment for this is there?
Gary
viperdude1
Chapel Hill ,TN
Re: Drivers Door Won\'t Stay Open
Gary
Gary ,
Yes the hinge will need to be replaced . The check spring is incorporated in the hinge and the parts are not serviced separately .
KURT E
Kansas City
Does the door close passively? My drivers door was rubbing along the weather stripping when closing. Opinions vary as to the fix from adjust to replace the hinge. The hinge is located under the plastic cover behind the front fender (hood) area. Pretty easy to get to, but, the hinge adjustment....*****. I did get it done, but, a "20 minute job" was much, much more.
Kurt
viper spray
Austin, Texas , USA
That hinge is the same on all GenI and GenII Vipers , left or right. I found one on E-bay. To fix the rubbing of the door on the weather stripping pull it up and gently grind down a little at a time, the plastic ridge that supports the weather stripping a bit to lower the weather stripping where it touches the door. I used a Dremmel tool and both doors now close like butter....................... spray.
luc
Paso Robles CA
There is a way to only replace the check spring and therefore not having to deal with adjustment issue.
Luc. 00GTS
xeng yang
