Drivers side window will not roll down??
AJT
Houston, TX , USA
I have an 02 RT. Anything common for a drivers window not going down. I already swapped switch & it works on pass side but not drivers?
Andy
Fast Viper Dan
Saratoga, CA, USA
The wire harness passes thru the door jam and into the door. This is a common problem. When mine broke the Viper Tec suggested he fix the harness rather than replace it. I guess he was able to reinforce the casing some how?
Dan
AJT
AJT
Houston, TX , USA
Thanks,
I jiggled all that & nothing happened. Started the car and it worked fine.???
Now my drivers door will not open from the inside????
This is weird???
Almost new battery in the car. about 6 months old...
Andy
drviperdds
Orlando
AJT. I'm having the same problem with the driver's door not opening from the inside. My window works fine though. I checked the door wire loom and could locate any breakage. My think it is the electronic entry module by the radio that is the problem.
Fast Viper Dan
Saratoga, CA, USA
Keep looking at all possible causes. Seems odd the problem fixed itself?
When my harness was acting up some times the door worked but the speaker did not another day the other way around? :confused:
zeeshan_k24
