Dumb ? Re: stage 3 adjustable coil overs
stew4706
The previous owner of my 04 Viper installed the Mopar stage 3 adjustable coil overs and I have been looking for some instructions on how to adjust. Obviously ride height is an easy one once I get the correct wrench - any suggestions?
Thanks for looking.
Dave
The previous owner of my 04 Viper installed the Mopar stage 3 adjustable coil overs and I have been looking for some instructions on how to adjust. Obviously ride height is an easy one once I get the correct wrench - any suggestions? Thanks for looking. Dave
I am not sure what product MoPar re-badges as you have described for gen 3?
Or Did they install an ACR suspension? An ACR-X? THose would be KW / G4. Does your car have Aero-downforce?
stew4706
He purchased direct from Mopar. It is listed in the catalog as 2 way adjustable coil over for non ACR P4510951.
MSRP $5185, virtually the same as the KW-Variant II $2000 less.
Instructions May be online at KW automotive North America, Inc. /// Be successful with KW suspension - made for Winners!
Info Here; KW coilover Variant 2 /// Sporty and individual with adjustable rebound damping
or if 3-way here: KW coilover Variant 3 /// Coilovers with State-of-the-art technology from motor sports
eucharistos
Houston
stew, do yourself a favor, call JonB
_________________________
While I am watching you....I am not preschool enough to say:
“Robert smells bad and looks worse” OR “Robert looks bad and smells worse”
Omaha NE.
Well my take on it FWIW is that they are actually NOT the V2 equal, they are aluminum bodied ACR shocks with different spring rates (blue springs also) and valving for non Aero SRT10's. So for about $700 less then the ACR setup you get one for normal SRT10's.
Omaha NE.
Sorry Jon not even close to the steel body V3 either...
Coilover Suspension System, 2-Way Adjustable, 2003- 09 Viper SRT10 Coupe, (Non-ACR vehicles). Coilover Suspension System: · Two way adjustable · Lightweight aluminum construction · Double adjustable (compression and rebound) · Ride height adjustable · Bridges the gap between street systems and full race systems
