Finsfan
All right guys and gals, I didn't see a thread with photos for DYI Batter Tender installations so, I figured I would throw one together. There are many options, so please keep in mind that this is just one of many. One of the things that I wanted to accomplish was to be able to connect and disconnect my Battery Tender with the hood closed and to try and hide wiring. So, here we go
Install time 10 minutes
I purchased my Batter Tender from one of our sponsors. Just my way of supporting the club.
Step 1: The first thing I had to do was modify the positive lead that came with my Battery Tender. The ring connect that came with my Battery Tender was too small. So, I replaced it with a 3/8" 3M connector (03858NA).
Caution: DO NOT Dis-connect Negative lead first.
Step 2: Removed the Positive lead from the fuse box. If this is the first time that it has been removed it will be very tight, so use caution.
Step 3: Remove the ground to frame connection.
Step 4: Route the quick disconnect lead behind your hood bumper guard as shown.
Step 5: Connect the Positive lead, and hand tighten / torque snug. CAUTION: over tighten and you will need to buy a new housing assembly, under tighten and it may cause your housing to over heat and melt. The factory nut has a built in locking feature. So, I simply torqued it until I could not move the positive lead.
Caution: DO NOT Re-connect Negative lead first.
Step 6: Re-Connect ground.
Step 7: I removed the back retaining screw from the bumper guard and installed a tie wrap with an eyelet to retain the quick disconnect.
Step 8: I installed a large red Remove Before Flight streamer to remind me to disconnect my Battery Tender before leaving the garage.
Here what it looks like when your done..
Enjoy your ride.
Enjoy your ride.
Great info which make sense. FYI, The warning was taken off of a set of jumper cables.
