Engine Mount Install Guide...
ViperTony
I just completed my engine mount and transmission mount installation and I have a ton of installation pics. If anyone is interested in a "How To" guide, I'd be more than happy to write one up in a couple of days. I had 3 sets of mounts handy:
- Tony
ViperGTS
Yes, please make a writeup.
And THANKS for the good work :D:D:D
ViperTony
I'm breaking up the guide into a few parts:
Part I: Jacking up the Viper
Part II: The Decision to Replace
Part III: Replacing Engine Mounts
Part IV: Replacing Transmission Mount & Crossmember
Here's an attempt at Part I:
Replacing Engine/Transmission Mounts Part I – Jacking Up The Viper
Since we'll be working under the car while replacing engine/transmission mounts its best to raise the car off the ground and give yourself enough clearance and be able to work comfortably and safely under the car. Unfortunately, I don’t have a lift so I resorted to putting my car up on Jack Stands. By using jack stands I was able to raise the car for 17” of clearance which is plenty of room for me to move around under the car.
SAFETY
Anytime you’re working under the car SAFETY should be the number one priority. I don’t know about you but I don’t like the idea of a 3,400+ pound car crashing down on me while I’m working under there. There have been too many stories lately of people getting crushed while working under their cars. WHILE THIS IS NOT THE ULTIMATE SAFETY GUIDE there are a few basic safety guidelines to keep in mind when jacking up the car and working with jack stands:
· Always work on a hard level surface such as your garage floor.
· Use a floor jack and jack stand that’s rated to handle the weight of your car, at least.
· NEVER work under your car supported by a floor jack alone.
· Use safe jacking points under your car. A jack or jack stand in the wrong location can cause vehicle and bodily damage.
· Never jack up your car without blocking the wheels.
· Make certain your emergency brake is set and your gearshift is set in first gear before you jack it up.
· Keep a phone with you while under the car and have someone check on you periodically.
Floor Jacks & Stand Styles
There are many different styles of floor jacks and jack stands out there to choose from. Our Vipers have low ground clearance so make sure you use a low profile jack. Low profile jacks have been discussed here on the forums numerous times so we will not be reviewing floor jacks here. Use this site's search feature if you’re interested in finding a good low profile floor jack.
Jack stands come in different styles. I have a set of Craftsman 3 ton jack stands that have served me well over the years. Not all Jack Stands are made equal. READ the warning labels and directions before purchasing/using your jack stands. For example, my Craftsman stands allow me to use 4 of them on all four corners of the car while my Pep Boy’s stands only allow me to use 2 at a time. It’s also important to use stands that can handle your vehicle weight.
Procedure
Our goal is to place two jack stands underneath the rear of the car and two jack stands underneath the front of the car. This will raise the vehicle evenly off of the floor and provide a sturdy support system. This can be accomplished by jacking up the car from the side jack points or via the front or rear frame sections. I chose to use to jack up the car using the front/rear frame sections. I decided to start with the front-end first:
(1.) Block off your rear wheels using wheel chocks. Start by jacking the front of the car. Although I’m using a low-profile jack with 3 ¾” clearance I used 2x10” pieces of wood under each of my tires so I get enough clearance to slide the jack under the fascia without scratching it. The goal here is to jack up the front of the car by the frame rails. Using either frame rail will lift the whole front-end:
Tip: If your jack doesn’t have protective rubber coatings you can use scrap pieces of carpet, rubber or heavy duty foam. The frame can scratch and dent easily so I always use a piece of heavy duty packing plastic packing foam on the jack and jack stands.
(2.) With the front-end jacked up, place a jack stand under either side of the car. We’re looking to place the jack stands between the “K” frame section and control arms as noted in the picture above. Try not to place the stands beyond the control arm bushing as we’ll need the space later in order to jack up the engine by the oil pan. Make certain the jack stands are of equal height once extended.
(3.) With the jack stands centered under the frame rails, carefully lower your car onto the jack stands. Check to make to sure your stands are centered under the rail and are sturdy (level and not leaning side-side). Readjust as needed.
(4.) Next we’ll jack up the rear of the car. I was able to jack up the rear of the car by one of the rear frame rails. The Viper’s frame is stiff enough so that both sides lift off the ground. Here’s the jack point I used:
(5.) With the rear-end of the car lifted, place a jack stand under either side of the rear under the “S” frame sections. Not sure if this the technical term but I call it the “S” frame bend because it looks like an “S”. I placed the jacks just before the bend as noted in the picture above.
(6.) Repeat Step #3 above to lower your car on the jack stands.
This is what my car looks like on all 4 jack stands:
(7.) Check the level of your car and make certain none of the stands are leaning toward either side. In the picture above, one of my front jack is leaning to the right in the picture above. Not safe at all. Time to adjust.
(8.) Check your car for sturdiness. Now that the car is up I check to make certain the stands are sturdy by literally pushing on the rear and front bumpers and checking to see if there’s any movement of the Viper. If done correctly, the car will not move side-side or front-back. It should feel solid with no movement. Although sturdy, with enough force the car can be pushed off the jacks with so be careful when working on the car.
(9.) As a precaution, I place a floor jack under a front frame rail and rear frame rail when the car is on jack stands JUST IN CASE. I’ll also place a stack of 2x10’s under each tire. I’m a little paranoid when it comes to working under the car.
If you’re not comfortable jacking via the front or rear frame sections you can jack your car using the side jacking points:
It’s not necessary to remove your side sills in order to use the side jacking points. Mine were already off for another upcoming project. Raising the Viper from the side will take a bit longer but works just as well.
Lowering the vehicle is a matter of reversing the procedure. I lower the rear first followed by the front. Don’t forget to place wheel chocks behind the rear tires before proceeding to lower the front of the car.
I can’t emphasize SAFETY enough when putting the car up on jack stands. Having said that, I make no claims that my procedure is 100% safe or correct. I hope you find this writeup useful. Comments, feedback and suggestions are welcome.
- Tony
CROM
Fairfax, VA
Nice, I am looking forward to the rest of your writeup!
I need to do a writeup on jacking a car up. I use 6 tons from sears with a min 18" height so no bent or wobbly jack arms like above. I also use a low pro floor jack. Easy cheesy and I get the car HIGH up and super secure.
Y2K5SRT
Overland Park, KS
Already copied this to the Illustrated Upgrades and edited it accordingly. Keep up the great work - we will be eagerly awaiting the next installment!
ViperTony
Thanks! It's amazing what you can do when you're out of work for the summer. :) So I'm taking advantage of the limited time off I have and trying to write up whatever project I'm doing on the car. CROM: Feel free to edit/add/redo my jacking procedure. I think it'd be great to have a detailed write up on how to properly jack up the Viper.
- Tony
ViperTony
The Woodhouse MM is very stout looking, but how safe is it over time not to have the interlocking tabs?
The Woodhouse mounts have an internal safety feature as well, just not the tabs. They created their own internal design for it. FYI.
ViperTony
Eagerly awaiting Part II!
LOL...I have Part II&III on the way.:D I got side tracked a bit as my wife said I was spending too much time in the garage so I was forced to pull a few weeds around the house the last couple of days but I'm back on the case! I will post them tomorrow.
Dave's Big Brakes
San Diego Ca USA
Hey Tony:D Is that like a Yes Dear:rolaugh: :rolaugh: :rolaugh: :eater:
Big Brake Dave:drive:
ViperTony
Pretty much...more like a "Yes Dear...oh by the way I ordered more stuff for the Viper...RUN!"
ViperTony
Replacing Engine/Transmission Mounts Part II – When to Replace?
A little History...
I didn’t wake up one morning and decide that the best thing I could do that day was to replace the engine mounts in my Viper…there’s a bit of history as to why I chose to replace my mounts and hopefully some of the things I came across during my research/investigation will help you in your engine mount endeavors should you choose to embark on this journey.
The stock engine mounts from 1992 to 2006 are nearly the same and are made of rubber. The nice thing about rubber is that it’s soft enough to dampen engine vibrations. This makes for less vibration in the cockpit. However, they cause lots of engine and transmission movement. They also get loose, separate, tear or warp with age. Unfortunately, stock Viper engine mounts have an above normal failure rate. I replaced my mounts on my ‘01RT/10 after 10K miles while other Viper owners replaced their mounts at lower mileage and higher mileage as well.
How do I know if my mounts are bad?
There are several symptoms to look for:
  • Missed Shifts
  • Excessive Wheel Hop
  • Torn / Separated / Twisted Engine Mounts
  • Torn Exhaust Hanger Isolators
  • Engine hitting your hood pad and/or cowl
At 6K miles or so, I noticed what I considered excessive wheel hop where it seemed as if my front-end jumped all over the road when going over the slightest bumps. After attending a tech session by Chuck Tator on stock shock adjustment, I learned that, at times, not all 4 shocks are set identically from the factory. Sure enough, I found that my shocks were all set differently. After correcting the adjustment, the wheel hop got better but was still noticeable.
I also missed shifts on a frequent basis particularly shifting from 3rd – 4th gear. My shifter was bouncing all over the place under heavy torque and over bumps. This was less of an issue on the track but still a nuisance nonetheless.
Around 10K miles, I decided to upgrade my entire exhaust system. This is when I noticed something wasn’t right with the engine movement I was experiencing. I found a torn exhaust isolator mount:
Think about this…there was so much engine movement that it caused the “J” hook hanger to TEAR through the isolator mount…It was also around this time that I decided to inspect my engine mounts. Since I had the car up on jacks it was easy to do from underneath the car. In case you don’t know what an engine mount looks like, here it is:
Upon inspection, I found they both had tears in them, around them and one was separated and the other one was warped pretty badly.
Driver’s side mount was separated all around and torn down the middle on one side:
Warped Passenger Side Mount:
The picture above doesn’t do it justice but the mount is twisted and separated.
Other Viper owners have reported that their hood pads had scuff marks from where the top of the engine was rubbing up against the pad from excessive engine movement. This was particularly noticeable with S.C. applications.
It’s worth noting that wheel hop is not solely due to bad mounts as other suspension problems can be contributing factors. In the end, if you’re not comfortable diagnosing your mounts then simply visit your Viper Tech for an inspection.
What about replacement mounts?
Polyurethane replacement mounts are available for Vipers. Poly is now the preferred material over rubber is more durable and lasts longer than the stock OEM mounts. During my research, I came across a couple vendors that offer replacement Poly mounts. Although there may be more vendors available I came across Poly Bushings and Woodhouse mounts.
For the purpose of this write up, we will not go into engine mount comparisons. Instead, go to the source…I called Johnny at PolyBushings, Mark Jorgenson at Woodhouse and Dave Cawthorne at Dave’s Big Brakes (he carries both mounts and ships really, really fast) to get my information on the construction, testing and design philosophy that went into each respective mounts. All three were very helpful throughout my quest. A little background on these two mounts:
The PolyBushings Mounts were designed as a heavy duty, direct replacement for the stock Viper engine mounts as well as other Dodge trucks. They have a similar design to the stock OEM mounts including the locking safety tabs. Of course, they’re made from Poly.
Woodhouse mounts were designed as an improvement over the stock OEM mounts specifically focusing on reducing engine and transmission movement, improving exhaust life and reducing secondary chassis movement. Woodhouse offers two versions for either street or track use. These mounts have a proprietary internal safety design which eliminates the need for the locking safety tabs. Also made from Poly.
Since I had all three mounts available, I snapped a few pics:
Once you’ve decided on the replacement mount it’s time to move on to Part III: Replacing Engine Mounts.
As always, comments, feedback and suggestions are welcome.
- Tony
ViperTony
Replacing Engine/Transmission Mounts Part III – Replacing Engine Mounts
Preface
I put in a lot of detail into this write-up and at first glance it may seem like a cumbersome and daunting procedure. It’s not. There's more detail than most people will need. When you boil this installation down there are basically 10 steps, or less, involved with replacing the mounts. It’s not a daunting task, take your time with it and you’ll be fine. In the end, if you're just not comfortable with raising and lowering your engine...don't do it. This installation guide is based on a Gen II Viper, specifically, a 2001 RT/10.
SAFETY
Now we get to the fun part of replacing our worn out engine mounts with Poly mounts. You’ll be working under the car for a good part of this procedure (unless you’re going to pull the engine out of the car). If you’re following Part I and have your car up on jack stands let’s remember some SAFETY guidelines from Part I:
  • Always work on a hard level surface such as your garage floor.
  • Use a floor jack and jack stand that’s rated to handle the weight of your car, at least.
  • NEVER work under your car supported by a floor jack alone.
  • Use safe jacking points under your car. A jack or jack stand in the wrong location can cause vehicle and body damage.
  • Never jack up your car without blocking the wheels.
  • Make certain your emergency brake is set and your gearshift is set in first gear before you jack it up.
  • Keep a phone with you while under the car and have someone check on you periodically.
  • Wear a pair of safety glasses or goggles while working under the car. I had all kinds of crud fall on me as I was pulling/installing the mounts.
Procedure
In a nutshell, the goal is to raise the engine about 3-4 inches off of the frame mounts, remove the engine mount assembly, replace the rubber mounts, install the engine mount assembly and lower the engine. The Viper has two engine mounts located on either side of the engine block towards the front-end. We will be replacing both mounts. We illustrated what an engine mount looks like in Part II.
1. Preparing to Raise the Engine – Check for Clearance
Before we actually raise the engine, we need to check for clearance around the exhaust headers, airbox and cowl. You don’t have to remove your side sills for this procedure but if you’re running aftermarket exhaust systems or have installed a wideband O2 sensor you should check your header turnouts for clearance in the frame.
I’ve installed Belanger headers and catback as well as an LC-1 Wideband Sensor in one of my turnouts. I needed to remove the WBO sensor so as not to crush it in the sills when raising the engine. Even with 3” exhaust pipe running through my frame I had plenty of clearance below:
I simply needed to remove my WBO sensor. For stock exhausts, you should have plenty of “flex” with the stock flex pipe turnout and no need to remove the side sills for this procedure.
Next, check for clearance where your exhaust header collector passes through the frame:
Top View – Driver’s Side Headers:
Even with my 1 ¾” Belanger Headers I had plenty of clearance between the frame. If you raise your engine and your headers hit the frame you may need to unbolt your headers in order to remove your engine mounts
Next, check your Air Box for clearance located on the passenger side whcih is mounted above the AC housing. I decided to remove my Air Box by removing two screws and two bolts:
Removing the Air Box is not required but gave me a better view of the engine block and mount. Don’t pay attention to the heat shielding on the air box…that’s another project in progress.J
Check your cowl cover and ignition coils for clearance. You shouldn’t have to remove the cowl cover for this procedure and you should have just enough clearance so that your ignition coils/wires don’t hit the underside of the windshield. In this picture, I have my engine raised with the engine barely touching the cowl and ignition coils/wires safely away from the windshield:
Lastly, let’s check the air intake box. I decided to loosen the air intake be removing the three screws that hold the air intake in place. This gave me enough flex so that the smooth tubes weren’t pulled off of the throttle bodies as I raised the engine:
2. We need to loosen a few bolts that hold the engine brackets to the engine and frame BEFORE raising the engine. Let’s start by getting under the car and loosening the bolts that hold the engine bracket to engine. Each mount has two bolts. Using your 9/16” socket, ratchet or wrench we want to loosen these two bolts on both mounts. We only want to loosen them at this point and not completely remove them, yet:
Bottom View / Driver’s Side Mount:
You’ll notice that the O2 wires are attached by a plastic hanger bracket located on one side of the engine bracket. These will get in the way in a hurry. Simply pop out the plastic retainer and move the O2 wires out of the way.
The passenger side is a bit of a tight space to work in compared to the driver’s side. In addition to the O2 sensor wire connector the passenger mount also has another wire attached to it via a metal bracket connected to one of the bolts. Simply move this wire out of the way and you’ll have enough space to work in:
3. Next, we’ll need to remove the 3/4” retaining nuts located under the frame under each engine mount:
My nuts were rusted and frozen pretty badly (insert your joke here). I sprayed penetrating oil into the nut and let it work for about 15 minutes. Using a 3/4” socket and long Flex-T handle I was able to break the nut loose and remove it.
At this point, you’ve loosened the bracket bolts and removed the isolator/frame nut on both mounts and you’re engine is ready to be lifted. You may also be wondering about that ‘other’ nut holding the engine bracket to the isolator (rubber mount):
We’re NOT going to remove this bolt until we remove the bracket assembly. There’s no room to get a wrench or breaker bar in there and break loose this nut from under the engine. I tried…
4. Now comes the moment of truth…raising the engine. Using a floor jack (screw jack if you have it) we’ll raise the engine via the oil pan. I used my floor jack and a piece of 2x10 placed under the oil pan to raise my engine:
With your jack centered under the oil pan, begin jacking up the engine. The goal is to raise the engine high enough in order to slide out the engine mounts, about 3-4”. You’ll hear some creaking and may feel the car rise slightly as the mounts loosen from the frame.
As you raise the engine, check the clearances we reviewed in step 1. If your headers, cowl, coils, etc. are hitting something STOP. We don’t want to damage any of these components. If your engine is not rising, rather the entire car is, STOP. Make certain you’ve removed the isolator/frame nuts in step 3.
After raising your engine a few inches, check the clearance of your mounts. They should be up off the frame with enough clearance to slide them out:
5. With the engine raised, remove the bolts holding the bracket to the engine we loosened in Step 3. With a little finesse, you should be able to slide the entire bracket assembly out from under the engine block. You may need to raise the engine a little bit if you can’t clear the bracket from the frame.
After removing each bracket I then labeled them so I could keep track of the orientation and which side each mount belonged to:
6. Using a bench vise, remove the bracket/isolator nut holding the bracket and mount together. My nuts were rusted and frozen so I sprayed more penetrating oil on them before loosening them. You’ll need a good amount of torque to get these nuts off (insert your joke here) so make you have a sturdy bench and vise to work on. Once you remove the nut the assembly will come apart and you’ll be left with the engine bracket, heat shield and rubber OEM mount. Toss the rubber mount.
7. Install your new poly mount to the bracket assembly. Whether you chose the Polybushings or Woodhouse mount, they both assemble in the same manner to the bracket. Make certain that the open end of the heat shield faces away from your headers and that close end faces towards the headers. You will need to reuse these heat shields even with the new mounts:
You’ll notice my mounts don’t have the interlocking tabs protruding from one side. That’s because I’m installing the Woodhouse mounts which have an internal safety design.
Using a bench vise, torque the bracket/isolator nut to 75 ft. lbs. The aluminum brackets dent easily as you can see from the picture above so be careful.
8. Install the brackets to the engine block by attaching one of the two bolts to the bracket and engine block. Yes, there are two bolts but we’ll use one bolt for lowering so that the bracket will hang down enough in order to guide the engine and bracket back into the frame...I learned this the hard way. After initially bolting the bracket securely to the engine and lowering the engine my brackets didn’t seat properly in the frame mounts and looked like this:
By installing the brackets with one bolt each, we allow the bracket bolt to guide the mount into the frame as we lower the engine:
9. With brackets in place, we’ll lower the engine. SLOWLY lower your floor jack until the engine is fully lowered and the mounts seat onto the frame. If you followed step 8, the engine mounts will be guided into place and your mounts will sit flush on top of the frame.
With the engine lowered and brackets in place, torque the isolator/frame nut to 75 ft. lbs:
Install the remaining bracket bolts to the engine & bracket and torque to 30 ft. lbs:
Don’t forget to attach the wire/metal hanger on to the bolt before you torque down the nut. This is the wire/hanger we removed from the passenger-side mount in Step 2. Reattach the plastic O2 brackets and O2 wires to the mount we removed in Step 2.
Install your air box, WBO sensor, side sills and cowl IF you removed them. Tighten down your air intake box if you loosened the screws in Step 1. Do a once over on your hoses, wires and ignition wires to make certain nothing came loose when we raised/lowered the engine.
If you removed your wideband sensor for the installation, you may need to perform a free-air calibration before installing it back into the exhaust pipe.
At this point, you’re done with the installation. It’s time to time lower your Viper and enjoy the new mounts…or is it? OR, you can take this opportunity while the Viper is raised and possibly work on the following:
  • Change the coolant, oil, transmission fluid, differential fluid
  • Grease your ball joints
  • Clean your rims, wheel wells
  • Detail your undercarriage
For reference, if you’re going to flush your coolant then don’t forget to drain the coolant from under your engine block. Drain plugs are located on either side of the engine block next to the engine mounts:
When you’re done…safely lower your vehicle and enjoy your new mounts. As always comments, suggestions and feedback are welcome.
- Tony
Viper X
Very good!:2tu:
I'm about to do the same job on my SRT-10.
Dan
ViperTony
Thanks...if you see anything wrong or maybe could be done better please add on to the writeup. I'll have the tranny mount install up late tonight. - Tony
A1998
Baltimore Ohio
Fantastic write up with Excellent Pictures and Quality!!:2tu:
I have just one question:
It appears that your Viper is mostly street driven like most of us. Could you point out why you went with the Woodhouse over the Poly Bushings? In researching both of these high quality mounts, I am having a hard time justifying a $110.00 price difference of the Woodhouse over the Polybushing. I would think they would both hold up for the same amount of time for a street driven car. :dunno:
v10kingsnake
south jersey
good write up. I had Tator guide me through the install on mine via telephone and he offered some great tips to remember which you might not. First, and VERY IMPORTANTLY, ONLY JACK UNDER THE OIL PAN AT THE VERY FRONT OF THE MOTOR. This is the thickest and strongest part of the pan. Otherwise you can crack it. Secondly, and it seems obvious to most, but he has seen it happen, LIFT YOUR HOOD WHILE JACKING THE MOTOR. Last thing you want to do replacing a couple hundred dollars in mounts is a cracked hood from forcing the motor up into it. Otherwise, great job. I commend you for doing it on jack stands. I used my revolution lift. Oh, forgot one more TATOR TIP: Once you set the new mounts in place and before you torque them to spec. Make sure you used a pry bar of some sort to sort of "rock" the motor back down in it's cradle all the way. He has seen many people and even techs re-torque the engine without doing this and it will cause drive train damage and premature mount failure.
ViperTony
Good question...yes, my car is street for now but I do track it. Woodhouse has two versions of their mount street & track. I'm using the street version, for now. I initially installed PB mounts which lowered my engine enough to make my header collectors hit the frame in the turnouts. The PB mounts are a bit thinner than stock OEM. I didn't want to mess with shims and the Woodhouse mounts are slightly thicker than the OEM mounts and actually gave me additional clearance with my exhaust.
RUCKDR was able to fabricate shims for use with the PB mounts. We should have pics added to the write ups on this soon.
The Woohouse mount is as big as the stock OEM mount and a bit thicker. As someone put it, its a stout looking mount when compared to the PB or OEM. Not sure if size matters here. You can see it in the pics. Not sure if size matters but the Woodhouse mounts look indestructable to me. Nothing against Polybushing's mounts as I think they're fine but the Woodhouse mounts are superior in design, fit and construction in my opinion. In the end, I called both vendors and asked a lot of questions. They were very helpful.
I still have my PB mounts and would love to test them out. I'm heading to the track tomorrow so we'll see how the Woodhouse mounts perform. I hope to try to the PB mounts in the next two weeks.
- Tony
ViperTony
Great tips...I'll modify the write up and incorporate these tips or at least append your response to it. Good info. This is my LAST mod without using a lift and I have been looking at the revolution lifts this week. :D
jay01m
Virginia
Very Nice! I just ordered new mounts for both the motor and the tranny, so this will be extremely helpful.
As for the tranny work, be sure to address the crossmember replacement. I didn't think I would need to replace that, but if I do, please explain why. Also, if this is the case, where is a good source for these crossmembers? Thanks!
ViperTony
Jay, owners have reported that over their tranny crossmember can twist under heavy torque. It hasn't personally happened to me. Davesbigbrakes.com has a beautiful billet aluminum crossmember that is far superior than OEM. Writeup should be up shortly.
Jim Wilson
Chandler, AZ, USA
Great write up! :2tu: I just replaced my motor mounts yesterday with the PB's. One thing I did differently was to cut about 1/2" off the motor mount studs. They don't need to be that long, and that's 1/2" less you need to raise your motor. This helps when you have headers, a wideband and DLM tubing.
inquiryhub
