Engine Serial Number
INSOMNIAC
Europe
Is there a way to find the engine serial number on my 2005 Viper SRT-10 online using the VIN number?
I believe it’s printed on the passenger side of the block but I can’t see it.
Thanks.
:usa: :usa:
Viper Wizard
South Salem, NY USA
Hey Art,
There are two numbers on your block, VIN & motor serial # and you can't get yours on line. It will only give you a range of motor numbers to build dates.
VIN#: The number is located on the rear of block just below the right cylinder head.
Engine serial #: The number is located on the lower right front of the block near the oil pressure sensor.
:cool:
I
INSOMNIAC
Europe
Hey Art,
:cool:
Thanks man.
I need the Engine Serial Number.
I guess I can’t find the engine serial number without lifting the car.
It’s pretty damn impossible to see from the top.
:usa: :usa:
Viper Wizard
South Salem, NY USA
Thanks man.
:usa: :usa:
Your welcome!
Yes you will need to get under her [that sounds good! :D ].
