Hey Art,
There are two numbers on your block, VIN & motor serial # and you can't get yours on line. It will only give you a range of motor numbers to build dates.
VIN#: The number is located on the rear of block just below the right cylinder head.
Engine serial #: The number is located on the lower right front of the block near the oil pressure sensor.
Thanks man.
I need the Engine Serial Number.
I guess I can’t find the engine serial number without lifting the car.
It’s pretty damn impossible to see from the top.
