Engine warning light.
Matrix
Germany, Stuttgart
Now the second time in 3 weeks the engine warning light is going on in my 2006 Viper. It shows P1494 (fuel leakage). § weeks ago, I turn the ignition 3 times one, i can see the P1494 and done! Then I take pull the battery off, the engine warning light is going out. Now, 3 weeks later the light is going on again! Anybody an idea what is going on? I have the paxton standard setup and the car runs with no mistakes and 7,5psi boost.
Fabian
Bobpantax
Miami
Could be the fit of your gas cap in the neck. Check it to make sure its a good seal when you screw it in. It does not take much for it to throw a code.
