Error code 24
SteveBCloud9
Roselle IL. usa
I've had my first error code come up on my 96' GTS. I'm getting error code 24 which is:
"Throttle position sensor input below/above the min. acceptable voltage.".
Anyone else have this error code? How did you fix it? Replace the sensor? Thanks for any help.....
Snake Bitten
Southern Kalifornia
Have you adjusted anything in relation to the throttle recently, if so (I see pedals?), call Sean Roe...he will recommend you clear the code by disconnecting you positive battery connection under the hood and letting the car "relearn" with the new adjustments...Sean's number is 904-733-5469...
SteveBCloud9
Roselle IL. usa
I've made no adjustments at all. I've already tried disconnecting the battery, the error just came back. There is nothing wrong with the car as it drives fine. Any other suggestions?
Viper Wizard
South Salem, NY USA
Possible Causes:
>Sensor signal circuit shorted to ground
>Loss of 5-volt supply
>Sensor signal circuit open
>Sensor ground circuit open
>Throttle position sensor failure
TPS Part #4761871AC MSRP $63.35
SKY1960
