Fuel system upgrade?
carl B
United Kingdom
Ok guys now I have the Roe S/C roller rockers headers, and a NX nitrous kit etc what fuel upgrade should I do
All your help would be appreciated
Carl
MadMaxx
Simpsonville, SC
The roe setup came with rails and injectors right? What size injectors are they?
Are you doing a DP nitrous setup? What are you goals for the fuel system? Are there any non-stock fuel pumps (inline or other) already on the car?
MadMaxx
Simpsonville, SC
Roe ships with 56lb/hr per website. I'm guessing thats rated at 100% dc. Those are 550cc injectors. You may want to step up to 720cc injectors (74lbs/hr roughly) if you decide to up the boost. 900hp V10 should require about 62lbs/hr@ 80% duty cycle. Nice flowing 720cc injectors can do this @ 80%.
As for fuel, you can use a single or duel inline pump setup. Duel pumps reduce the chance of fuel starve in the event of a failure, but means more plumbing. -10 lines should be plenty big to flow the fuel needed. Since you're working with the top feeds and custom rails, you have a lot more options for power growth than the stock (internal) rails.
C
carl B
United Kingdom
could have screwed up here!
When I ordered the kit from Sean and the 5lb pulley he didn't mention the injectors were different when you go up to the bigger pulleys
Perhaps I should talk to him and see if I should do the larger pulley and injectors now?
Since thats the way I will be going later anyways
Carl
MadMaxx
Simpsonville, SC
I don't know if he offers an injector upgrade, his injectors should support ~700hp crank safely. I know that you can run larger pullies, but w/o intercooling you will get detonation. Some have rigged up alky/h20 injection to compensate for lack of IC, and are able to run ~2lbs higher boost threshold. You can dump a full tank of C16 in there and have a field day ;)
PS. My math is off slightly due to the fact I never trust injector ratings to flow what they say they will w/o a flow test. You can go larger and make it flow less fuel if needed, but not the other way around ;)
Simms
Pittsburgh, PA
I beleive no matter if its 5lb or 8lb Sean gives you the option of injector size. As 99 RT/10 said, the 42lb/hr are standard with the 5lb pulley, but you can upgrade to the 50lb/hr injectors and still run the 5lb pulley. The 50lb/hr injectors are required for the 8lb setup as well as an MSD voltage booster. 1TONY1 uses a Kenne Bell boost-a-pump instead.
I have also seen 10lb setups still using just a voltage booster. Other combo's using water/**** or similar injections take advantage of the addition fuel to keep the air fuel safe. Some are also runing a 10lb pulley with better flowing heads (with less compression) to keep detonation down. A good tuner can work with you for different combinations.
C
carl B
United Kingdom
well I hope the 50lb/hr are what is included in my kit.
It was never mentioned when I ordered it though?
It should arrive Tuesday!
I am looking for green top injectors........right?
Thanks again!
Carl
Qualitywires.com
Louisville, KY
If you do an external fuel pump...I recommend not sticking it in the drive shaft tunnel due to it being a bit noisey in there. Macedos sells I think..some rubber mounts for the external pumps. The Viper is noisy as is so I am going to relocate my pump soon somewhere else to keep things quiet.
I don't know if Roe uses a return line or not, but you may want to put a fuel cooler on it also to keep the heat down on it. Cost is minimal to do.
Simms
Pittsburgh, PA
Thanks again!
Carl
If you get the 42lb/hr injectors, I am sure you can exchange them with Sean and just pay the upgrade cost. It used to be $100 more for the 50lb.
C
carl B
United Kingdom
The news is good!!
The kit arrived yesterday and I see there are the 53/lbs injectors in there so we should be good for now!!
Am going to go with a different fuel pump setup later
Carl
BarryLB
