Gen 1 PCM pinout
Bill B
Plantation, Fl. 33323
I'm looking for an ECU setup to run a GEN 1 engine in a project car. I am unable to find all of the components to do this with stock parts ( ignition module, wiring harness) Haltech Thought they may be able to help if I can get the pinout. Anyone got it?
Thanks.
SingleMalt
Hi Bill -- Your best bet would be to get the service manual that cooresponds to the PCM you have for the engine. Otherwise, if you are looking at using an aftermarket controller, you will likely need to solicit the help of a tuner that has experience with standalone controllers a-la MoTec...
Mike
BarryLB
