Gen 2 Interchangeable intakes?
Jance GTS
Oklahoma City, Oklahoma
I'm planning on smoothing out my intake and getting it colormatched. To save time on the project I have found another intake to buy so I can smooth it out and then just swap them out. I was wondering if they will be a direct swap?
I have a 2000 GTS. I was told this intake come off a 1999 GTS.
Is there anything I need to know before I buy this?
Thanks!
Here are the numbers on the intake I'm looking at buying.
AFL in NJ
Rancho Cordova, CA
I was thinking of doing the same thing....using port matching and then extrude honing it....what are your plans for the intake internally?
Regards,
Aaron
97snk
Jance I've a 97 gts intake sitting in my garage. Let me know if you are interested. I went with a extrude honed intake...
cal jonb or mike 99 rt10 and ask them as they are knowledgeable. but im pretty sure any gen2 will work. cant think of any differences. but call one of them
JonB
Legacy\Supporting Vendor
Columbia River Gorge
.....call jonb or mike 99 rt10 and ask them as they are knowledgeable. but im pretty sure any gen2 will work. cant think of any differences. but call one of them....
Yeah, one of my favorite things is handling tech support calls and questions to make it easier for you to buy stuff off of flea-bay instead of from me...... Makes me feel all tingley and special inside!!!!
Jance, Your answer is YES, a 99 and a 00 intake manifold are interchangable. But if its cracked, will the seller have another?
J
Jance GTS
Thanks for the info Jon! It's not on ebay and this one isn't cracked. :2tu:
Should I do any mods to it internally?
JonB
You could certainly take the opportunity to port-match the throttle-body and runner inlets, even with a dremel tool.... will yield snappier throttle response and maybe 10 HP...
Extrude-Honing is expensive and time-consuming, but effective IF you have other flow-mods planned.
mattraff
