Gen-4 Articulating Variable Camshaft
Cape Coral, FL
I know some of you guys just LOVE do-dads... well, here you go.
I have a SLIGHTLY damaged Gen-4 Camshaft. It has ONE lobe that is scored, but is otherwise perfectly usable. It could certainly be repaired by either welding, or finding another camshaft that is a total loss and taking one of the lobe sections from it. Hell, it could technically be run as-is, since the score isn't actually as wide as the roller, and runs perpendicular to the roller movement... the roller would just go over the top of it. The movement of the exhaust sections is still functioning fine.
Here is your chance to play with one of these... for a LOT less than normal.
Camshaft normally sells for about 1250.00 new. Have this one in your hands for 395.00 obo
zeeshan_k24
