Just take your shocks to a tire/brake place, most have a spring compressor like the one in this pic
Then when you go to remove the fork, Spray with penetrating oil and let sit for an hour or 2, then bolt the fork in a vice, then grab on with a pipe wrench, use a bar to give you better leverage and if that doesn't work, buy a $50 torch from Home depot and heat up the black fork just under where the coil over is bolted in, this will expand the aluminum fork enough to break any seal and then the coil over will unbolt easily.
