Gen III heads on a Gen II - Is this possible?
FE 065
MI
Bigger question might be what's the price of 2 complete GenIII heads compared to having yours ported?
Torquemonster
Auckland, New Zealand
Perhaps - but if money is not too tight you need to remember that the Gen 3 heads START where your ported Gen 2 heads STOP. I'd go Gen 3 in a blink if the money wasn't an issue. Max ported heads can crack over time too - another reason to consider the Gen 3 and go mild on the porting.
There's 900hp+ potential on motor alone in the SRT10 heads.
FE 065
MI
If they start where ported GenIIs leave off,
then bolting on GenIIIs would add 50hp or more..?
Vipermed 97.01
Tampa Fl. USA
Well said and true.As far as the header flanges the new header design that we are making will have the flanges designed to work on gen 1,2 and 3 without changing out headers or fabricating anything
Marv S
Scottsdale, AZ
any issues to bolt on the gen2 accessories and gen 2 im or exhaust manifold onto a gen 3 head?
Ron
Indianapolis
What about the intake? Could one stealthly use the GENII or would that be too much of a limiting factor in the flow?
Fast Freddy
TUCSON, AZ - USA
i thought gen-3 motors are having problems with there valves. like sucking them or something. anyway isn't there a recall on that. either way what is that all about and what is the solution 2 the problem?
Y2K5SRT
Overland Park, KS
There were +/- 200 cars recalled due to the valves not getting a final grind/cut at the supplier. Resulted in no damage to the motors or any problems besides a slight loss of horsepower and torque. Affected cars could be fixed at a dependable (which there are not enough of) dealership and be on the road again in a day with new valves. There is no recall on the other 2003's.
Fast Freddy
TUCSON, AZ - USA
hey vipermed. do gen-3 heads use 1.7 ratio roller rockers or do they use 1.6 ratio. also will my t&d 1.7 ratio roller rockers that i just bought from you and have yet to install on my gen-2 heads bolt onto the gen-3 heads? if so do the gen-3 heads need to be altered in some way to accomodate my t&d 1.7 roller rockers?
Vipermed 97.01
Tampa Fl. USA
The factory gen3 heads utilize a 1.73 rocker, they use a bearing style arm but do not have a roller tip and gen2 T&Ds will not retrofit
Anthony - 98 GTS
Houston, Texas
The Gen III intake *****. Not sure if its the plenum volume or what - but it is a restriction on the Gen III's.
KenH
Portland, OR, USA
Numbers just aren't adding up IMO.
The GenIII is suppose to have far superior heads than ported Gen II heads, higher ratio rocker arms, better intake manifold, better intake air filter system and is bored/stroked out for more CI. With all that, they are only putting down about 20-30RWHP more than a Gen II. Sorry, but I'm not buying the far superior theory of the Gen III parts.
Take a GenII, port the heads, add higher ratio rocker arms, extrude hone the intake, add your favorite smooth tubes and filters or whatever and bore/stroke it out to 505CI and you are going to add a lot more than 20-30RWHP.
--- Ken
Fast Freddy
TUCSON, AZ - USA
i hear gen-3 heads have 2.00 inch intake valves. is this true? and what size exhuast valves do they have? also what size valves do gen-2 heads have?
Martin D
Dunwoody, GA USA
Ken, the problem with the Gen 3 cars is the intake manifold. The heads do flow better. Gen 3 heads and a gen 2 intake.....that is the ticket.
Regards,
Vipermed 97.01
Tampa Fl. USA
Marv, yes, the Alternator will require a custom bracket....
Actually the alternator will mount just fine with no special brackets needed,all mounting for alternator are on the frt. cover.Problem lies in mounting the power steering pump on the left side of the motor as the gen3 heads have no place to mount the P.S pump bracket.We are in the process of developing a conversion kit.
Martin D
Dunwoody, GA USA
Duh.... I knew that. thanks for catching me med.......I mean really, alternator, power steering pump, WHATS the difference??? :D
Torquemonster
Ken - your points sound logical except that the intake on the SRT10 is not better it is rumoured to cost 60hp due to being too short in the runners and unequal distribution issues, plus you assume the cams are the same.
The fact is the Gen 3 heads could make over 1000hp without any boost or chemical supercharging in full drag race prep. No one probably will because few bother to build 8000rpm Viper V10's for all out power. But they are a jump up from anything you can do to the Gen 2 heads.
A nicely prepared Gen 3 conversion on your Gen 2 engine with Gen 2 intake manifold etc will net a lot more than 30rwhp.
This conversion is going to become the hot item in the months to come - watch and see the results as the tuners start putting them out and getting them sorted. Add boost to these heads and we'll see new benchmarks.
Jay Herbert
Sunnyvale, CA
All the tuners I have spoke with are really impressed with the flow (volume and characteristics)of the stock Gen III intake... as noted above, they love the heads too.
KenH
Portland, OR, USA
Just seems like there has to be a weak link in there somewhere, whether it be the intake or something else. You can't have that many better or equal parts and not have more HP than they are showing (stock).
I thought I heard that the CAM was the same, but perhaps they have made it even more creamy smooth? Anyone know for sure what the CAM specs are for the '03? I thought the Comp Coupe had the same cam as the normal '03 and when I had the opportunity to hear one run the other day, it sounded fairly aggressive to me, but maybe that was just the lack of anything resembling a muffler coupled with running on an echoy showroom floor!
--- Ken
Anthony - 98 GTS
Houston, Texas
The intake is the weak link. :(
FE 065
MI
More importantly, is the combustion chamber on a GenIII of different volume than a GenII?
spicydangernoodle
