GEN1 Head bolt torque #'s - Help!!
klamathpro
Detroit
I don't know which is right, stick with the manual or go with Chuck's numbers.
The manual and Archer Racing says to torque the head bolts to 30ft-lbs. and then to turn 90 degrees. Archer's tech said nothing changed as far as torquing the new metal gaskets . But in the following post from five years ago, Chuck said to torque them down to 125ft-lbs. :omg: !!!
http://forums.viperclub.org/showthread.php?t=534550&highlight=gen1+head+bolts+torque
That's a huge difference. If Chuck's right, then do I torque to 30ft-lbs first and then go over and re-torque to 125ft-lbs? :dunno: Experienced responses appreciated. What worked for you?
95Viper
Phoenix
Call Chuck, depends on year and whether you are reusing yor bolts or not.
K
klamathpro
Detroit
It's a 94' and I am reusing the bolts.
Chuck's a great guy. I hate to bother him with every question. Anyone already ask him this before?
95Viper
Phoenix
As usual, Chuck knows. Although I paid $800 from him for the gasket set and was ticked at the time it feels like a bargain now. I called Chuck 3 or 4 times during the install and he walked me through everything. Made the $800 pain go away.
K
klamathpro
Detroit
Thanks Chuck. So I torque the bolt sequence to 45ft-lbs. Then go over it again to 90ft-lbs and then once more to 120ft-lbs.
Wow, my heads might have flown away with the original specs in the book.
Viper Wizard
South Salem, NY USA
That's it!
I've probably done close to 200 of them by now and I can say that not one of them have had any head gasket leaks since.:cool:
Sinusbeats
